My brakes
11 replies to this topic
#1 minidude03
minidude03
  • 462 posts
  • Local Club: Mini Club Jersey
Posted 22 June 2004 - 08:41 PM
what size are my brake discs, the car is a standard sprite, with 12 inch wheels
#2 Pickup76
Pickup76
    Ring Runner 2005
  • 1,191 posts
Posted 22 June 2004 - 08:46 PM
If the car is totally standard as you say, it should have 8.4" disks that are standard fitment to all minis with 12" wheels.
#3 minidude03
minidude03
  • 462 posts
Posted 25 June 2004 - 09:05 PM
will 10 inch wheels fit on if i use 1" spacers
#4 Purple Tom
Purple Tom
  • 4,921 posts
Posted 25 June 2004 - 11:29 PM
it depends on the wheel you are using, and of course you will need to fit longer studs to your drive flanges to compensate for the spacers. Wella's may fit, Mamba's definitely won't, 10x4.5 or 10x5 MWS Minilites won't (i need 1/8 spacers to get them over 7.5 discs with 4pots), other wheels may do depending on the offset and the interior diameter. Steels almost certainly won't.
Tom
#5 minidude03
minidude03
  • 462 posts
Posted 26 June 2004 - 06:07 PM
revolutions 6x10
how do i measure the offset
i'll measure the interior diameter now and get back to ya
#6 minidude03
minidude03
  • 462 posts
Posted 26 June 2004 - 07:10 PM
:D
#7 minidude03
minidude03
  • 462 posts
Posted 26 June 2004 - 07:11 PM
does this help?
#8 Purple Tom
Purple Tom
  • 4,921 posts
Posted 26 June 2004 - 11:13 PM
Its possible, although i'm pretty convinced they won't. You might be lucky with spacers, but you really need to try before you buy. Ideally you need to get your discs machined down to 7.9", and fit smaller calipers, this will save on the extra loading and stress put on your hubs from the spacers.
#9 lewis
lewis
  • 2,322 posts
Posted 28 June 2004 - 10:52 AM
isnt that a good bit of money though?
#10 Purple Tom
Purple Tom
  • 4,921 posts
Posted 28 June 2004 - 11:03 PM
well yes it is, probably in the region of £300 for the machining and the new calipers, but if you want to run 10's then thats the only way to do it, other than to buy a set of cheap S discs and rebuild the calipers, cv's, ball joints etc yourself, which would work out about the same i'd imagine, if you add in your own labour time. Depends really on what your after.
#11 lewis
lewis
  • 2,322 posts
Posted 28 June 2004 - 11:18 PM
as i thought we were discussing the money side the other day, hes off to spain now though for two weeks, he was deciding to buy a set of new alloys and wheels for bout 400 + but hes on a budget, any other ideas to have nice wheels for the lad? :cool: get on the cool side with non standards :D
#12 Purple Tom
Purple Tom
  • 4,921 posts
Posted 28 June 2004 - 11:25 PM
some split rims would be nice, siggy and woody know quite a lot about those rims, they'd be able to tell you more - but i'd amagine for £400 you'd be talking 'budget' tyres
