Opinions On Flip Fronts
Best Answer rusty30 , 10 February 2014 - 03:41 PM
5, 4, 3, 2, 1 .... Go to the full post
14 replies to this topic
#1 Tweakz
Tweakz
    Just On Tickover
  • 9 posts
Posted 10 February 2014 - 03:13 PM
Im just wondering what people think about flip fronts
I just want to get some ideas on what i can do for my project
#2 rusty30
rusty30
  • 112 posts
  • Local Club: Mini Clan
Posted 10 February 2014 - 03:41 PM   Best Answer
5, 4, 3, 2, 1 ....
#3 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 10 February 2014 - 03:47 PM
fine on a grass track car etc
makes a road car look cheap
#4 fwdracer
fwdracer
  • 269 posts
  • Local Club: Mini7 Racing Club
Done well they make working on Mini a piece of p***. Most are just dangerous bodge ups. Road car? Recomend use steel panels and add triangulation from top of bulkhead to leading edge of subframe if the inner wings are removed.
#5 DomCr250
DomCr250
  • 667 posts
  • Local Club: 16V mini club
Posted 10 February 2014 - 03:53 PM
As Fwdracer says, done well in steel they look great and also make working on a mini really easy - almost essential for some types of 16V engine swaps.
#6 Tweakz
Tweakz
    Just On Tickover
  • 9 posts
Posted 11 February 2014 - 09:05 AM
Thanks guys
Yeah i can see why it makes it easier to work.
Thanks for your views on it ill get some pics on soon of the project but it will be a slow one cause working it around college and work.
#7 Carlos W
Carlos W
  • 10,114 posts
Posted 11 February 2014 - 09:10 AM
You need a way of it not hitting the ground when you flip it forward too!
And flexing may be an issue
#8 Tweakz
Tweakz
    Just On Tickover
  • 9 posts
Posted 11 February 2014 - 09:19 AM
I think i might scrap the flip front seems more hassle then its worth
I just wanted to see what other people think of them.
#9 Carlos W
Carlos W
  • 10,114 posts
Posted 11 February 2014 - 09:26 AM
If it's about access to the engine, you can get some hinges which move the bonnet higher, they were advertised on here the other day!
Articulated bonnet hinges!
I'll see if I can find you a link!
#10 Tweakz
Tweakz
    Just On Tickover
  • 9 posts
Posted 11 February 2014 - 09:32 AM
Cheers lad muchly appreciated
#11 Carlos W
Carlos W
  • 10,114 posts
Posted 11 February 2014 - 09:34 AM
These aren't the ones I was looking for, but it gives you an idea!
#12 Tweakz
Tweakz
    Just On Tickover
  • 9 posts
Posted 11 February 2014 - 09:36 AM
Thats brilliant thank you this should help a lot thanks
#13 splintercat
splintercat
  • 616 posts
Posted 16 February 2014 - 05:40 PM
Saw a nice set up at last years MITP......gut had a hinged one bonnet BUT lifting up not forward.....think he used Morris Minor hinges as  I think they are much longer....think you could use this on a one piece front....different....a bit like the front of a Mk1 Frogeye Sprite.
#14 'Chop'
'Chop'
    They don't call me chopper for nothing!!!
  • 543 posts
  • Local Club: 3 Custardeers Mini Club
Posted 16 February 2014 - 06:02 PM
I made mine from a selection of steel mini panels, wings, front panel and A panels and welded them all together (as in a standard front end) but decided I wanted mine completely removable. The front end attaches to 2 bolts in the front subframe, 2 on each A panel (which bolt into brackets I made that bolt to the back of the door hinges) and 2 bolts which bolt through a triangulated panel which goes from the scuttle to the inner arch.
I fitted brace bars to build a bit more strength into it.
The wiring loom is detachable, so I can access ALL around the engine once the bolts are undone and front end is thrown to one side.
The bonnet bolts onto the front end through the top corner bolts (see above) and bottom corners through more triangulated plates.
#15 md7708
md7708
  • 79 posts
Posted 16 February 2014 - 06:17 PM
posted about possibly doing a flip front on my mini earlier sonikk4 gave me a link to some pretty sweet looking hinges i think i may just purchase a set of these
http://minivation.ne...culated-hinges/
