How To By Pass Immobiliser?
Posted 10 February 2014 - 04:40 AM
I have search the forum but could not find how to by pass Immobiliser.
Need great help.
Here is my problem.
1. Car start normally with immobilizer disconnected (has been this way when I bought the car).
2. clock not working since I bought the car, however when the engine was running, there was light on the clock and work. The clock stop when the engine was not running.
3. connect clock positive to permanent power supply.
4. clock now working and left it overnight.
5. clock was still working the next day
6. Try to start engine, starter wont turn over (not even a click sound from starter).
7. Plug in immobilizer, car starts normally
8. Un-plug immobilizer, starter wont turn over (not even click from starter).
Please help how to by-pass the immobilizer
Car details:
Car : Rover Mini Cabriolet
Engine no: 12A2EF77XXXXXX
chasis no: SAXXNNBYCBDXXXXXX
Year make: 1993
Thank you.
Regards.
Posted 11 February 2014 - 06:29 AM
I might be missing something here; but if the car starts and runs with the immobiliser installed why do you want to remove it?
Posted 11 February 2014 - 08:45 AM
Please help.
Thank you.
Regards.
Posted 11 February 2014 - 06:08 PM
I don't think they are that problematic, I've been in to minis and on this forum for nearly two years and its not something that I would say crops up to often.
Happy to be corrected but I thought the system was quite reliable
Posted 11 February 2014 - 06:39 PM
I've had my SPi since new 20 years ago and never had any problems with the immobiliser. I haven't used the alarm for many years but it all still works.
I wouldn't worry about it unless it becomes an issue later. There are plenty of other things to worry about...
Posted 12 February 2014 - 12:25 AM
FS
Posted 12 February 2014 - 04:33 AM
Good to hear that it is quite reliable.I don't think they are that problematic, I've been in to minis and on this forum for nearly two years and its not something that I would say crops up to often.
However I am puzzle why when I first bought the car it start without immobiliser.
Will use with immobilizer for now and hopefully can do without it one day.
Thank you for your feedback.
Regards
Edited by seria, 12 February 2014 - 04:36 AM.
Posted 12 February 2014 - 04:39 AM
As above two points 1) why do you want to remove imobiliser when it's isn't a known issue? 2) the imobiliser is there to prevent your car being stolen;why do you think someone in open forum is going to post the info to bypass it even if they known how to do it
FS
Thank you. It's ok not to lock the car over here.
Regards.
Posted 09 May 2014 - 01:16 PM
While driving the other day the alarm light was flashing. Reach home park the car and off the engine. Try to start the car, totally no start ie the starter did not turn over. Totally dead. Please help where to start.
Thanks a million.
Posted 09 May 2014 - 08:04 PM
Is this a single button fob type ? prob is as mine is the same and its a 1994 I can pm you how to do it you wont believe how easy it is.
Posted 09 May 2014 - 11:17 PM
You have a PM.
Thanks.
Posted 10 May 2014 - 08:43 AM
Please do not post on here how to do it. I WILL REMOVE IT. This is a public forum so open to anybody.
Any answers please do so via pm as somebody has done. Thank you.
Posted 03 April 2018 - 07:53 PM
Hi,
I have exactly the same issue - is some one able to pm me PLEASE before this problem drives me to an early grave!
Thanks for any help.
Damian
Posted 03 April 2018 - 09:32 PM
pre 1995 factory alarm/ imobiliser is not 'passive', it does not arm its self, it has to be armed by using the fob. If you do not arm the alarm/ imobiliser it will remain off.
As for what you describe, it sounds like someone has altered the wiring, meaning it will be difficult to comment accurately on any solutions.
Edit* Like a dope, I replied to a post from 2014
Edited by Sprocket, 03 April 2018 - 09:37 PM.
Posted 12 April 2018 - 09:16 PM
Hi,
Thanks for your reply, really appreciated.
I have a grey, one button fob with the keys. the car did start without using the fob. The fob has no Rover markings on it, so I'm not sure its Factory.
I have fitted a Specialist Components engine and their ECU. I have replaced the top wiring harness (that which connects to the relays and ECU in the engine bay), fuses/box etc and am going through the pain of getting the new engine/ECU to fire.
Can the immobiliser be bypassed - the Vin records a '93 SPi.
Any suggestions at all would be hugely appreciated.
Cheers,
Damian
