Glad to see it came out. Can't tell from the pic. Are there thread marks on the broken piece where it got stuck. I have a pic of 850 crank that shows thread starts much deeper than where it got stuck. Try crank bolt if you haven't already to see if threads are damaged.
Again glad to see it worked.
I too am so glad it finally came out! There are no treadmarks on teh piece. The crank bolt won't go inn, so there is at least some damage to the treads. If I put a finger inside it doesn't feel like a lot of damage, but I guess it's hard to tell this way.
I've seen this before, and I've also split one of the trust blocks in two when under load...
Which is why, this part of the puller is also being looked...
Now the question is... have your ordered the right tap for the crankshaft ????
What do you mean by "this part of the puller is also being looked"? Sorry, my English might be inadequate. Do you mean it is a problem area that is looked at?
The tap i ordered is 5/8 Witworth. I really hope I'll be able to fix the treads!
Having suffered most of the above throughout the years I always remove and engine to change the clutch/remove flywheel.
Not only does it aide removal but re-assembly.A friend of mine has half a foot due to a flywheel coming loose!!!
Sorry to hear about you friend! That is frightening! Did it happen during disasembly or did it come loose when the engine was running?
I am not sure if I would have been able to remove the flywheel unless I had a enginestand that was bolted to the floor. So great was the force needed to get it loose that, despite using a long lazy-mans-arm, I had a sore back and arm the day after. I think I would just have pulled the enginestand around the garagefloor.
But to get that piece out, it would definately have been easier with the engine out.
