Try drilling into the broken off piece and screwing a screw extractor into it the left handed spiral should grip your drilled hole easily and as it is not threaded it should come out with a little coaxing.
See #9 post, 36 hours ago....!
Posted 10 February 2014 - 07:23 PM
Posted 11 February 2014 - 02:14 AM
flywheelpuller2.jpg 34.74K
33 downloads
crankshaft.jpg 56.32K
55 downloads
This is what the pieces look like. The last 7 hours I have attempted to get is loose, but it is crazy-stuck!!! I have now made a slot with an anglegrinder and a dremel with a cutting disc, and tried to lever it to turn anticlockwise in order to release it from the crank. I have broken or bent a few screwdrivers and wrenches in the process.
crankshaft2.jpg 58.08K
50 downloads
This:
crankshaft3.png 11.74K
7 downloads
is the approach I had the most faith in because of the leverage it gives. Blue lever is supposed to illustrate a drift, brown is supposed to be a screwdriver. It still won't move even a fraction of a millimeter.
Posted 11 February 2014 - 06:55 AM
My understanding of the problem is shown on the attached sketch where the broken piece has been jammed into the crank threads. Top sketch.
Middle sketch shows piece being sheared and jammed into crank... thin section? Picture of puller earlier post shows thicker section.
Fracture appears to have surface like a casting surface fracture.
I might try the bottom scheme. drill and tap thru the broken piece make thread large as possible without drilling into crank.
Use threaded rod socket and nut as shown to draw the broken piece out.
Posted 11 February 2014 - 11:28 AM
Posted 11 February 2014 - 04:11 PM
Your understanding of the problem is spot on!. Solution also looks like a good idea. I have bought a 90 degree drill and managed to drill hole in the pice. I'm trying to tap threads in it, but I am challenged for space, so I hope I'll manage to produce good threads. I'll see if I can get it out using your method tonight!
Posted 11 February 2014 - 05:04 PM
If you get the bolt in, you could then weld it in there then twist the broken bit out??
Posted 12 February 2014 - 03:06 AM
Good luck... hope it isn't jammed too tight and not acting like a Chinese finger trap.
Posted 12 February 2014 - 05:19 PM
Posted 14 February 2014 - 02:05 AM
Fanally! That little rascal is out!
I used your method tsumini. I was even surprised it came out so easily once I had managed to produce treads in the piece. Maybe I had it nearly loose using all that force earlier.
Now next challenge is if I can renovate the treads in the crankshaft! Tap is ordered.
flywheelpuller3.jpg 33.31K
39 downloads
Posted 14 February 2014 - 03:55 AM
Glad to see it came out. Can't tell from the pic. Are there thread marks on the broken piece where it got stuck. I have a pic of 850 crank that shows thread starts much deeper than where it got stuck. Try crank bolt if you haven't already to see if threads are damaged.
Again glad to see it worked.
Posted 14 February 2014 - 06:46 AM
Posted 14 February 2014 - 07:24 AM
I've seen this before, and I've also split one of the trust blocks in two when under load...
Which is why, this part of the puller is also being looked...
Now the question is... have your ordered the right tap for the crankshaft ????
Posted 14 February 2014 - 08:23 AM
Posted 14 February 2014 - 08:44 AM
Posted 14 February 2014 - 08:49 AM
