V8 Engine Or The Biggest One
43 replies to this topic
#16 Kieranlee999
Kieranlee999
  • 1,401 posts
Posted 07 February 2014 - 11:22 AM
There is a red V8 van around too. The Beast. Thats rocking a Rover V8 and RWD. Its got a monster diff and massive rear wheels.
Took these at imm09
i wonder what the 0-60 time in that is then :P
#17 joakwin
joakwin
  • 958 posts
Posted 07 February 2014 - 12:14 PM
http://ls1tech.com/f...ini-cooper.html
v8 mini's
#18 joakwin
joakwin
  • 958 posts
Posted 07 February 2014 - 12:15 PM
v8 mini's
#19 RedRallyMini
RedRallyMini
  • 309 posts
Posted 07 February 2014 - 01:51 PM
215 cubic inch Buick v8 rear engined Mini Cooper:
Edited by RedRallyMini, 07 February 2014 - 01:53 PM.
#20 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,031 posts
  • Name: Neil
Posted 07 February 2014 - 02:03 PM
#21 james962
james962
  • 2,677 posts
Posted 07 February 2014 - 03:04 PM
You have to really define what you mean by "in" a mini :lol:
#22 Chris Jones
Chris Jones
  • 90 posts
Posted 07 February 2014 - 03:06 PM
Can't see the point of putting a big heavy V8 lump in the back of a mini. The Rover ones don't kick out all that much power in comparison to a nice modern 1.8/2L turbo as someone mentioned before.
As a project to see what can be done though, fair play.
#23 jt19
jt19
  • 745 posts
Posted 07 February 2014 - 05:42 PM
Just doesn't look or sound right in my opinion.
Fair play for building one though to see what could be done lol
#24 mab01uk
mab01uk
  • 12,390 posts
Posted 07 February 2014 - 07:36 PM
All British Leyland parts, transverse (side ways mounted) engine and front wheel drive just like proper Mini's ! :lol:
http://reocities.com...2760/Viku2.html
Rover V8 3.5L engine on transverse Austin Princess fwd gearbox for the Mini Clubman V8
"Plan included fitting the engine transversely like the original Mini layout, finding a suitable gearbox/diff and mating everything together. Gearbox is originally from an Austin Princess. It is of Mini design, located underneath the engine. Surprisingly the Rover block and Princess gearbox fitted pretty easily (?) together with only a few adapter plates. Flywheel is a combination of Range Rover and Princess parts. The clutch is a combination of late model Rover clutch plate and Saab turbo diaphragm. A new final drive was specially designed and machined for this engine, ratio is around 2,7:1. The engine is tilted backwards about 10 degrees."
"Carb is a 390 cfm Holley which also needed modifications to gain bonnet clearance. Engine is rebuilt and fitted with a hotter camshaft. Viku fabricated one-off exhaust manifolds with stainless steel and mild steel tubing. His mini has "only" a single exhaust because the dual would not fit and he wanted some stealth effect… Well, the exhaust note is hard to miss !!! Cooling is taken care of with a Mini 2-row super cool radiator and a specially made auxiliary radiator.
Surprisingly enough suspension components and suspension pickup points are all ORIGINAL. Furthermore, bulkhead is also original, no cutting was required !!! Like you see in the photos, the package is pretty tight but everything fits. What is even more surprising is that this car does not feel over engined. It runs just about the same way an original Mini does. Only difference being the extra torque…"
Edited by mab01uk, 07 February 2014 - 08:01 PM.
#25 sonikk4
sonikk4
  • 16,031 posts
  • Name: Neil
Posted 07 February 2014 - 07:41 PM
I think looking at what that Rover lump has fitted i would put money on there being at a minimum 250 BHP and probably more depending on the bottom end. Now that coupled with a decent glob of torque would make for a very quick mini. And if you see that clubby in the flesh its the skills that have gone into building it that are impressive.
#26 jt19
jt19
  • 745 posts
Posted 07 February 2014 - 08:16 PM
Don't get me wrong I like the skills involved in these kind of conversions!
#27 Artful Dodger
Artful Dodger
    " I AM THE SPECIAL ONE"
  • 4,435 posts
Posted 07 February 2014 - 11:23 PM
HAHAHAHA NO WAY!!!
How pointless is that^^. Inventive! But hilariously pointless:P
#28 mab01uk
mab01uk
  • 12,390 posts
Posted 09 February 2014 - 11:29 AM
'Practical Performance Car' Magazine - Aug 04 page 30-36 write up on yellow FWD V8 Mini Clubman here.
Scroll Down:
http://spagweb.com/v...scrap/index.htm
#29 mab01uk
mab01uk
  • 12,390 posts
Posted 09 February 2014 - 11:34 AM
Edited by mab01uk, 09 February 2014 - 11:38 AM.
#30 jmmini
jmmini
  • 711 posts
Posted 09 February 2014 - 03:46 PM
yeah there are a few V8 minis. mostly 3.5 rover v8 units.
pretty pointless if you ask me..   stick a small capacity engine with a turbo on, much better and better power capabilitys really.
Plus with the wheelbase of a mini the v8 is wasted imo
