Gearbox Parts List
Posted 06 February 2014 - 09:24 PM
Posted 06 February 2014 - 10:12 PM
Posted 06 February 2014 - 10:30 PM
I got mine from minispeed. Scott was very helpful and my gearbox builder was very impressed with the quality of the parts and that everything was covered. I needed a replacement gear and misc bits which guessworks sorted.
Posted 06 February 2014 - 11:39 PM
Posted 07 February 2014 - 12:06 AM
I just asked Scott to give me what they would put in a fully rebuilt box. His list was more comprehensive than the others and much cheaper.
Posted 07 February 2014 - 12:15 AM
Posted 07 February 2014 - 07:44 AM
Posted 07 February 2014 - 08:38 AM
Is there a way I could get a hold of said list?
I haven't kept it. Just phone a few suppliers and ask what kit they do or could put together. I'm pretty sure the Minispares site still lists a kit with details of what's in it.
Posted 07 February 2014 - 09:09 AM
Everyone enjoying the lovely weather. Been thinking since I had time on hands considering re doing my gearbox and if anyone has recently re done one and if they have a parts list or would it be cheaper and better in the long run to send it in and get the whole engine re done just opinions and help please.
Unless you want to do it yourself, because you want to learn, then you should consider Guessworks (on here). First rate service and quality, good prices too.
Posted 07 February 2014 - 10:02 AM
The 5 major bearings will cost nearly £200 retail for genuine RHP...
- 1 x AAU1365 ROLLER DOUBLE FOR MAINSHAFT IN GEARBOX
- 1 x AAU8424 ROLLER 1st MOTION SHAFT PILOT TO CLUTCH CASE
- 1 x ADU7619 ROLLER SINGLE TYPE FOR HOLDING 1ST MOTION SHAFT
- 2 x AHU1856 DIFFERENTIAL ROLLER
We've all ready the stories about 'unbranded' wheel bearings.... gearbox bearings are no different...
Posted 07 February 2014 - 10:32 AM
Posted 07 February 2014 - 11:26 AM
Bloody hell, they got expensive !!
Long gone are the days of an £80 gearbox kit then !!
Phil.
Posted 07 February 2014 - 11:34 AM
I suspect someone will try and supply an £80 gearbox kit, but shafts will be made of rubber and bearings made of cheese...
As a bit of guidance when I rebuild an A+ gearbox I use the following...
- 13H9513 x 2 - NEEDLE ROLLER 1ST MOTION/LAYSHAFT 4 SYNC
- 22G2033 x 4 - BAULK RING
- 22G2262 x 6 - SYNCHRO SPRING
- 31B447 x 1 - SEAL UNDER ROD CHANGE SELECTORS TO GEAR CASE
- AAU1365 x 1 - ROLLER DOUBLE FOR MAINSHAFT IN GEARBOX
- AAU8424 x 1 - ROLLER 1st MOTION SHAFT PILOT TO CLUTCH CASE
- ADU5738 x 2 - DIFF OUTPUT SHAFT OIL SEAL
- ADU7619 x 1 - ROLLER SINGLE TYPE FOR HOLDING 1ST MOTION SHAFT
- AHU1856 x 2 - DIFFERENTIAL ROLLER
- BLS107 x 6 - SYNCHRO BALLS
- BTA101 x 2 - DIFFERENTIAL THRUST WASHER STANDARD SIZE
- C-22A1739 x 1 - LAYSHAFT A PLUS performance
- C-AHT54 x 1 - OIL PIPE HITECH CENTRAL PICKUP GEARBOX
- C-BTA164 x 1 - DIFFERENTIAL PIN WITH MOLYBDENUM COATING
- CCN110 x 1 - PILOT BEARING CIRCLIP
- CDU1563 x 1 - O ring seal for aluminium bush selector shaft
- CHM141 x 1 - LAYSHAFT LARGE ROLLER
- DAM5071 x 2 - WASHER THRUST WITH LIP FOR PLANET GEAR,A PLUS
- DAM6624 x 2 - PLANET GEAR
- GHF221 x 1 - 1/4" UNF Nyloc nut
- GHF223 x 1 - 3/8" UNF Nyloc nut
- TUK100320 x 1 - BEARING ROLLER TYPE FOR A PLUS ONLY FITTED 1996 ON
And the customer gets with the gearbox
- 13H2934 x 1 - CLUTCH OIL SEAL (ORANGE)
- AJM804B x 1 - GEARBOX GASKET SET
Sometimes the needle bearings under the 1st, 2nd and 3rd gears need replacing, these are approx £15 each new.
