Compression Ratio Calculations - 1275 +60 Cooper S
4 replies to this topic
#1 dgear1984
dgear1984
  • 287 posts
Posted 02 February 2014 - 09:13 PM
Hi,
Ok built up the block, spec below. Rob walker will machining the head, just need to let him know a cc.
cooper s 1275s thin flange block +60
21253 pistons
12g940 1805 head flowed and ported by Rob Walker
35.7 and 31mm unleaded valves with 3 angle hard seats and bronze guides
piper billet cross drilled bp270 with 1.3 forged rockers
97 fuel
Checked the deck height to pistons and I am getting
cyl 1 = 10.5 thou
cyl 2 = 9 thou
cyl 3 = 8 thou
cyl 4 = 8.5 thou.
I burette the block and got 9.7cc per cylinder with 8.4cc of that being the dish of the piston.
Wrote a excel spread sheet and that worked out the cc per cylinder to be between 9.23 and 9.48cc (allowing for the slightly different deck heights). What I have no allowed for is the gap around the side of the piston and the top of the top ring, was unsure what this figure would be with the +60 21253. A 0.22cc and 0.47cc difference between the theoretical and burette figure.
For the excel sheet I have used the bore at 72.124 (1275 +60) and the stroke to be 81.33mm
Assuming I go for a 10.5:1 ratio, with cylinder 1 being the lowest compression due to the largest deck height (10.5thou) and cylinder 3 being the highest ratio due to the smallest deck height (8 thou). I have allowed 3.4cc for the gasket.
With a head of 22.2cc excel gives me a comp ratio of 10.53:1 (cylinder 3) and 10.47:1
Look about right, anything I have missed
Thanks Dave
ps. I am happy to upload my excel spread sheet for others to use, maybe someone can message me and tell me how is best to post it.
#2 grumpy dad
grumpy dad
  • 305 posts
Posted 03 February 2014 - 01:26 AM
HI
I think the head gasket is 2cc
but you should wate for AC Dodd to come along and comforme
#3 ACDodd
ACDodd
  • Mini Docs
  • 2,743 posts
Posted 03 February 2014 - 05:50 PM
I make that 10.15:1 with a bk450 gasket on cylinder no.3. I would run 10:1 cr with that cam and rocker combo. Therefore I would use a 22.8cc chamber.
Ac
#4 dgear1984
dgear1984
  • 287 posts
Posted 03 February 2014 - 06:32 PM
Ac
Hi thanks for the reply. I am using a minispares GEG300 gasket which claims to have 3.4cc rather than a bk450 which gives 4cc.
I have done some research and it looks like the ring land is around 0.5cc. Have added the ring land to my calculations.
Does this look correct, what have I got wrong as I am still getting slightly different figures to what AC quoted. With a 22.8cc head and changing the head gasket to 4cc, I still get 10.1:1 rather than 10:1 which AC says
ScreenShot2014-02-03at183402_zpseaf9a54c
Thanks Dave
Edited by dgear1984, 03 February 2014 - 06:35 PM.
#5 ACDodd
ACDodd
  • Mini Docs
  • 2,743 posts
Posted 03 February 2014 - 07:23 PM
Ok using your figures I get 23.8cc to get 10:1.
Ac
