Rear Subframe Refurbishment
20 replies to this topic
#16 JonnyAlpha
JonnyAlpha
  • 2,748 posts
  • Local Club: Exmoor Minis
Posted 11 February 2014 - 10:30 AM
You can buy the bracket from M Machine
11.32.02.27 Bracket, Rear Sub Frame Mounting with captive nuts, LH 4.50 5.40
11.32.02.28 Bracket, Rear Sub Frame Mounting with captive nuts, RH 4.50 5.40
Thanks sonikk4
#17 JonnyAlpha
JonnyAlpha
  • 2,748 posts
Posted 11 February 2014 - 09:20 PM
Well today I managed to remove the Rear Subframe single handed!!! and didn't break anything in the process!!!
Quite impressed with myself :-)
At first glance after a quick brush off with a wire brush it looked in pretty good nick all things considered however on closer inspection with a screwdriver a found a couple of rusted areas:
First spot is inside rear RH side:
Second spot is on the front top RH side:
Is the rust damage in both the pics above weldable? Or am I looking at a replacement - can't afford a new Subby!!!
The front mounting trunnions also look a little worse for wear but these can be replaced can't they?
Heres the whole thing out - not a lot of space in my garage I'm afraid!!
#18 Big_Adam
Big_Adam
  • 7,435 posts
Posted 11 February 2014 - 09:41 PM
Power wash the poop out of it.
Gosh dang it, I love power washing.
#19 wile e coyote
wile e coyote
  • 1,230 posts
Posted 11 February 2014 - 09:43 PM
Well done that man! Taking a sub out on your own is a bit of a faff but very satisfying  when it comes out that nicely....a good clean up and I'd reuse those trunnions...
After all that what state is the heelboard in?
As regards the subframe the corrosion on the top is easily weldable...... the penetrated corrosion  by the spring however...hmm personally I'd replace the whole frame - it looks very very thin in places - theres not much meat in the metal on a new frame anyway but the rib below the spring really does look wafer thin and with holes....having experienced a subframe letting go it really isn't funny - not to mention dangerous....
So IMHO it's either "bodge" (sorry) now or bite the bullet and be confident in the long term integrity of your car...
#20 JonnyAlpha
JonnyAlpha
  • 2,748 posts
Posted 12 February 2014 - 06:49 PM
As the Subframe came loose on the LH side I was confronted with nice hole into the sill, I was not surprised to be honest!!!
However, the rest of the Heelboard on first inspection seems OK :-) but I'll know more once I clean it up.
Here's the whole - pretty standard I suppose:
The LH side of the Mini seems to be the worst all round.
With regards to the Subframe like I said a new Subby is out of the question, but that said I'm not going to skip on safety, i'll clean this one up so I can have a good look then I'll make a decision as to whether I can affect a repair or seek out a second hand subby?
Edited by JonnyAlpha, 12 February 2014 - 06:56 PM.
#21 bpirie1000
bpirie1000
  • Area Managers
  • 2,341 posts
  • Local Club: Amoc
Posted 12 February 2014 - 08:19 PM
Different stubby for me afraid....
Welding may attract crabbing.....don't want rear to overtake the front.....
