"new" Distributor From Boot
electrical
16 replies to this topic
#16 GageHolding
GageHolding
  • 48 posts
  • Local Club: Bournemouth Mini Club
Posted 04 February 2014 - 03:58 PM
fitted it, couldn't get it to fire, read it might be the coil type so swapped to the other coil I have lying around, still no firing, was getting cold and fed up so back to original distributor and coil and back to the drawing boards!
Need to go get a new starter motor soon so might get them to check it out then!
#17 ado15
ado15
  • 614 posts
Posted 04 February 2014 - 05:30 PM
1983 should be a 12V coil, but if it happens to be an early ballast ignition system, your coil will be 9V. If you are taking the power feed from a 9V coil on a ballast system, the electronic ignition won't work. It will need a separate switched 12V feed.
