I have been given a TIM Ammeter, it's in the box and I think it's unused but has no instructions. What I am asking is how to wire it in. I have looked in the Moss catalogue and they have two listed, one for a dynamo and one for a alternator, what is the difference? My car has an alternator.
Ammetere
Posted 25 January 2014 - 10:59 AM
Posted 25 January 2014 - 12:13 PM
it is very difficult in a Mini, because you have to join all the brown wires together that were originally on the battery terminal of the starter solenoid, into one thick wire, and run that to one ammeter terminal, the other ammeter terminal goes back to where you removed all the wires from. All of this extra wiring is unfused, and therefore a major fire hazard. And, there will be extra voltage drop, which will affect the battery charging.
It is common practice on alternator-equipped cars to never have an ammeter, but instead have a battery condition meter, which is a voltmeter with expanded scale, reading only the useful range, maybe 10 to 15V.
Remote sensing ammeters exist, and if you had one of these you would pass all the brown wires through the hole in the hall sensor. The ammeter itself would need 12V power from the ignition-controlled circuit via an in-line fuse.
Posted 25 January 2014 - 12:43 PM
Here is a typical current sensor. Note that it needs to be provided with _ and - 15V, and will need some kind of instrument to read its output of up to 50mA remotely.
http://www.farnell.c...eets/797312.pdf
Posted 25 January 2014 - 03:12 PM
Posted 29 January 2014 - 11:34 AM
Posted 29 January 2014 - 12:01 PM
Posted 29 January 2014 - 03:16 PM
connected them to one side of the ammeter and connected the other side of the ammeter in their place.
Posted 29 January 2014 - 03:52 PM
This should show a discharge of the total current draw which it apears you have with the lights on, when the engine is running at 2000-2500rpm this should bring the amp to a plus charge and then slowly decrease back to 0, this is if the meters accurate? I would put a voltmeter on the battery and with the engine running at 2000rpm with everything off you should see 13.7-14.3v across the battery which confirms it is charging correctly, if you dont see this voltage then carry out tests on the alternator to see why.
Posted 30 January 2014 - 01:56 PM
I am sure it's all ok it's just that I expected to see more charge.
Posted 30 January 2014 - 05:10 PM
It should if the amp meter is working bring the meter back to 0, i would do the test with the volt meter on the battery and if thtas ok bin the Tim
Posted 30 January 2014 - 05:22 PM
If the battery is healthy and full and the engine starts well then a single start might not take a huge amount out of the battery. It could conceivably only put it into a low current charge rate. You said the gauge registered a small charge but you didn't say how much.
Posted 30 January 2014 - 05:41 PM
