I have had an 1994 Mini Coopper (SPI) for about 18 months all has been generally well for about 15 months and then a Problem
It has an Imobliser under the dashboard and I believe that after reading this forum that it is NOT coded to the ECU as the ECU is an MNE101070.
Q1. I did not get a Key FOB or anything for the Imobiliser, but was wondering can I still buy a FOB for this Imobliser. ( before I have to take off the dashboard etc to get to the UNIT for serial nos etc)
Q2 If Yes to the above who supplies them.
Q3 I assume that the little RED LED on the dashboard indicates if the imobiliser is set ( never seen it on yet)
Q4 I am having problems with the car recently and was wondering if the imboliser could be interfering with the car. We get a situation where after driving a relativily short while the car stops and on trying to restart the ignition appears dead. No oil pressure light or battery light . Wait a few mins ( and dont do anything) and all is normal and it starts up. !!! But can then die again.
Just Massivly puzzled as to why we seem to loose the Ignition and OIL pressure lights. Clock Light and Radio still operate.
Q5 Also Ocassionally appears to loose power on a corner or when you are slowing down but picks up after wards
I have for Various Reasons replaced the following
New Battery ( 4 Months ago)
New Alternator ( 1 week ago)
New Coil ( 1 Week ago)
New Condensor (1 Week ago)
New Relay Pack ( 1 Week ago)
New Fuel Filter ( 1 Week ago)
New HT leads ( 6 months old)
New Spark Plugs (6 Months old)
Am about to check out a few of the Vacuum pipes and replace as they assume loose. But these on reading the Posts on the Forum do not seem critical as the ECU can rervert to Default modes
I have invested in a code reader and there are NO error messages showing on the ECU and all component tests Pass
Am also Going to add a extra Earth Strap to Engine to some other point on the Body ( the Earth Point on the Engine Bracket is so hard to reach ( and people seem to have problems with earthing in General on Mini)
Just Massivly puzzeled as to why we seem to loose the Ignition and OIL pressure Lights, Clock Light and Radio still operate
Many Thanks in advance
