Water Heated Alloy Inlet Manifold
21 replies to this topic
#16 timmy850
timmy850
  • 3,238 posts
  • Local Club: MITG
Posted 21 January 2014 - 09:55 PM
It does also provide a more consistent intake temperature, as the tune can at times change slightly under different ambient temperature conditions
#17 jaydee
jaydee
  • 8,565 posts
Posted 21 January 2014 - 09:59 PM
If only i had a penny for all the times i've been posting this
Heated manifolds have no ability to prevent carb icing, it happens in the venturi. You'll need a dashpot heater to prevent this.
The heated manifold was introduced simply because the better vaporization gives a better combustion resulting in 'cleaner' emissions and a slightly better mpg, and lees chance of going 'out' of tune' because the manifolds are stabilized to a certain temperature.
#18 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
  • Local Club: Loan wolf
Posted 21 January 2014 - 10:13 PM
Just plumb it up, looks neater.
#19 Mr Joshua
Mr Joshua
  • 378 posts
  • Local Club: Rebels mini club
Posted 21 January 2014 - 10:16 PM
For all of you who think carb icing is the symptom and water heated inlets are the cure, please explain how the carb remains free of ice first thin on that cold damp morning until the water system has heated up sufficiently to heat the inlet manifold because the cylinder head just does not get hot enough to do this on its own. Bearing in mind 80% of engine cooling is carried out through the cylinder head (please correct if wrong). So that the cylinder head can keep all of this heat transfer from the inlet manifold to the point it requires the water system to transfer the head instead i would argue is mere fantasy.
Discuss.
#20 Mr Joshua
Mr Joshua
  • 378 posts
Posted 21 January 2014 - 10:17 PM
Dude no words wasted there talk about bullet point lmao.
#21 mk3 Cooper S
mk3 Cooper S
  • 5,569 posts
Posted 22 January 2014 - 02:47 PM
Pipe it up on a seperate cooling circuit if you want to cool the charged air/fuel mixture for optimum performance
#22 HarrysMini
HarrysMini
    I do not have short legs!!!
  • 3,352 posts
Posted 22 January 2014 - 03:03 PM
Contrary to my above post, mine is actually connected up, but I have it within the heater circuit. Therefore, when it's cold, and I have the heater on, the manifold is heated. And when it's hot, and the heater is not on, there's nothing going to the manifold.
Best of both worlds.
What I certainly wouldn't do, is put it somewhere where it would be permanently heated.
