Water Heated Alloy Inlet Manifold
21 replies to this topic
#1 Jmadry
Jmadry
  • 41 posts
Posted 21 January 2014 - 05:07 PM
Hi I was wondering if anyone has any experience with using water heated inlet manifold. I have run one before but not had it plumbed in for the heated water. If anyone could explain the science behind these and the advantages and or disadvantages that would be great. any explaination of setup or pictures of setup etc would be great. thanks a lot.
#2 mk3 Cooper S
mk3 Cooper S
  • 5,569 posts
Posted 21 January 2014 - 05:08 PM
Water cooled I think
#3 welshdan
welshdan
  • 643 posts
  • Local Club: ?
Posted 21 January 2014 - 05:31 PM
water HEATED
#4 DomCr250
DomCr250
  • 667 posts
  • Local Club: 16V mini club
Posted 21 January 2014 - 05:55 PM
The water heating is supposed to help with icing up in the winter - basically it's when the inlet temp falls so low ice crystals form.  On a normal mini with a cast iron inlet and exhaust the heat from the exhaust prevents this.
Some people connect it, some people don't - the manifold sits on top of the exhaust manifold, so some latent heat gets sucked into the inlet manifold anyway.  I think if you live in a very cold climate then it's probably a good suggestion to connect it ... in UK it's maybe not that much of an issue.
#5 grumpy dad
grumpy dad
  • 305 posts
Posted 21 January 2014 - 05:56 PM
Hi
just a quick one
when it is plumed in the water starts to heat the inlet manifold quickly
pros
get you of choke quicker stops carb iceing
cons
the hotter the inlet charge is the less air
so you get less petrol in
#6 HarrysMini
HarrysMini
    I do not have short legs!!!
  • 3,352 posts
Posted 21 January 2014 - 05:57 PM
There is really very little point in connecting it up.
And before anyone says it, it is not to do with carb icing.
And yes, I'm sure it is for heating, not cooling.
#7 Cooperman
  • 23,325 posts
The idea was introduced to make the car run better in cold weather.
A lot of us just by-pass the water-heated manifold to ensure the inlet charge is as cool as possible as a cool charge will give more power at normal operating temps.
But others like the heated manifold, so it's personal choice.
All early Minis, including Cooper & Cooper 'S' didn't have heated manifolds and they went OK.
#8 Carlos W
Carlos W
  • 10,114 posts
Posted 21 January 2014 - 06:14 PM
If it's connected to the heater circuit, I suppose you can have it heated when it's cold and not heated when it's hot??
#9 Mini ManannĂ¡n
Mini ManannĂ¡n
  • 2,859 posts
  • Local Club: man Estate
Posted 21 January 2014 - 07:18 PM
I definitely didn't want mine http://www.theminifo...beautiful-swan/ :D  The cooler the inlet charge the denser the charge is so more POWER  :trooper:
#10 AVV IT
AVV IT
    I am a shed dragger.
  • 6,122 posts
  • Name: Dave
Posted 21 January 2014 - 07:26 PM
As I understand it, the main purpose of the heated inlet is to aid with fuel atomisation in cold weather conditions, by helping prevent fuel vapour condensing on the inside walls of the inlet. The standard cast inlet manifold doesnt require this, as it is in effect heated by way of it being cast/joined to the standard exhaust manifold below. Aftermarket alloy inlets are completely separate from aftermarket exhaust manifolds though, therefore a water heated alloy inlet is supposed to go some way to compensating for this.
So in my opinion there is a point in connecting them up, but wether you'll actually gain any benefit depends on what you actually use your mini for. I have two 1275 minis, one with the inlet plumbed in and one with it not. Both cars behave very similarly in warm/mild weather conditions . The difference between the two is very noticeable on cold mornings though, with the plumbed in version running more smoothly, much more quickly, and requiring much less choke than the non plumbed in version does.
So if you're using your mini all year round as a daily drive, then I'd thoroughly recommend that you plumb your heated inlet in. Whereas if you 're only using it over the summer months, then I probably wouldn't bother, as you're unlikely to gain any benefit from doing so. If your mini is a highly tuned monster, or a track car that you're looking to squeeze every last ounce of performance out of, then you're likely to want your induction tempetature to be as cold as possible, so you probably won't want to plumb your heated inlet in either.
#11 Cooperman
  • 23,325 posts
Posted 21 January 2014 - 07:28 PM
I could never see the advantages, despite being told by various people that without a heated inlet I would get carb icing, poor cold running, bad mixture, etc.
I have never had on in over 50 years of building, driving, rallying and testing Minis.
Just think, a lot of engines have turbos with intercoolers to make the charge as cool as possible. say no more ;D.
#12 Jmadry
Jmadry
  • 41 posts
Posted 21 January 2014 - 07:33 PM
thanks for all the input, very interesting so far.
#13 carbon
carbon
  • 2,590 posts
Posted 21 January 2014 - 07:46 PM
Carb icing up is no urban myth.
I had this happen to me on a '76 998 mini. This was using standard cast iron inlet manifold with standard single HS4 carb & BL filter. The trumpet on the air filter was in the 'summer position' at the time, taking cool air rather than warm air from near the exhaust manifold.
It was not a particularly cold day either, but was very damp. Not a pleasant experince when it happens - basically the throttle jammed open and then all you can do is either stamp on brakes or switch ignition off.
#14 HarrysMini
HarrysMini
  • 3,352 posts
Posted 21 January 2014 - 07:49 PM
It's not a myth, but a heated inlet manifold is not to prevent it icing.
#15 carbon
carbon
  • 2,590 posts
Posted 21 January 2014 - 09:50 PM
OK, for the benefit of the OP I will continue...
Following on from the icing up problems with my 1976 998, I made the following changes. In time honoured manner the cast iron inlet manifold was sawn off the exhaust manifold so I could continue to use the standard exhaust. The replacement inlet manifold was a small bore Oselli Torquemaster, keeping the HS4 carb with a bit of Vizarding to the internals, and with a K&N filter and stub-stack replacing the standard air filter box. No attempt made to pick up hot air from the exhaust. Inlet piped up to take permanent hot water bypass. Rest as before.
I never experienced any problems with carb icing on this set-up and this was used for several years as a daily driver in all weather conditions.
So in my (limited) experience, a water heated inlet manifold can prevent carb icing.
