Speedo turns per mile
#16
Posted 06 December 2007 - 01:45 PM
#17
Posted 07 December 2007 - 02:46 PM
#18
Posted 07 December 2007 - 03:22 PM
#19
Posted 07 December 2007 - 03:29 PM
so if i were to have a 2.76:1 FD and i got the right drive gears in the gearbox then i could run the km/h speedo as a mph one? odes that make sense?
#20
Posted 08 December 2007 - 10:04 PM
hence why they are called gauges. if they were supposed to be accurate they would be called instruments.
hahahaha.. funny that they are also 'known' as an 'instrument cluster'... :s
bad terminolgy: like those that say 'diff ratio' when refering to 'final drive ratio' for example
#21
Posted 04 June 2015 - 12:55 PM
Yep, 1320 had the same questions raised by moke owners in Aus'... they have 800rpKm speedo's
If it's in rpKm then multiply by 1.609344 to get TPM
*apologies for the thread revival
So I've got a smiths speedo in km/h
Small number above odometer reads 880.
880 results in a 1416.2 tpm.
This seems extremely high?
Edited by MiniNoobJhb, 04 June 2015 - 12:55 PM.
#22
Posted 04 June 2015 - 02:55 PM
actually it's 1408 tpm which is normal. I got fed up with all the decimal places... so x 1.6 works
so you must have a 170/180 kph centre speedo from a 60's cooper ( not cooper S )
http://www.guess-wor...ech/ratioKM.htm
Edited by Guess-Works.com, 04 June 2015 - 02:58 PM.
#23
Posted 01 July 2016 - 09:40 AM
Is a km speedo in TPK??? If so and it says 800 on the dial does that mean a TPM of 1280?
#24
Posted 01 July 2016 - 10:32 AM
Yes, spot on
See above link for Metric ratio calculator.
Edited by Guess-Works.com, 01 July 2016 - 10:34 AM.
