I think my battery has gone flat, so the central locking won't work. To add to this, my driver door lock is stiff and the key won't open the door. I've tried WD40 in the lock and managed to fully insert the key, but I can't turn the lock to open the door. I called out a roadside recovery company and he managed to put a wire handle into the side of the window to pull the door handle from inside, but the door didn't open. He tried a few other options and gave up.
Anyone got a solution, other than a suble brick throught the driver's window?
