Hi there,
I'm having some distributor issues and I'd appreciate some advice on the best options given my current situation.
I'm running a standard A+ 998 (1990) which has a standard lucas 45D distributor with points.
Today I broke down, and with a friends help came to the conclusion that my distributor has a few issues. We got the car going again by fitting what I think is an Accuspark electronic distributor that he had lying around (he's a handy guy to know). Sadly I need to give it back to him!
What we discovered about my dizzy is that firstly, the advance plate wasn't rotating at all as the screw holding the points on was too long and was effectively locking the plate in position.
Once we rectified this by packing the screw out with washers and still couldn't get it running right I noticed that the plate doesn't spring back as it should. So if the vacuum advance does act, it doesn't really return to its normal position. My only theory is that if it's been locked in that position for a long time, maybe the springs have stretched.
I should also mention that a while ago I renewed the points, condensor, cap, rotor arm and also fitted a lucas 'gold' coil at the same time. My learned friend suspects that this uprated coil could be frying condensors, although I was told at the time of purchase that it'd be fine with my otherwise standard ignition system.
So... I have a distributor which isn't really in a state where I can just upgrade it with an electronic module to do away with the points as it is in need of some refurbing anyway. Also, I've looked at electronic distributors and I'm amazed by the range of prices for a complete unit (£50 to £400).
Do people think that my gold coil could have fried a new condensor in less than 100 miles?
Will my gold coil be up to the job in the long term if I upgrade to electronic ignition?
Are there any refurb options for my old 45D (replacement springs for starters)?
If it makes sense to throw the old distributor away, what is the best choice for someone who is prepared to pay out for something which will last, and might even want to consider allowing for future tuning options, but whose money tree is currently bearing little fruit?
Thanks in advance for any advice you might be able to offer.
Neil.
