Do i need to remove this circlip to get the shaft out of the outer cv joint?
Been trying for hours now, can't seem to get it off :/
Posted 18 January 2014 - 11:48 AM
Posted 18 January 2014 - 11:57 AM
Posted 18 January 2014 - 12:07 PM
That's not the retaining circclip, it's a depth stop.
The circlip in internal and cannot be seen or reached with the CV on the driveshaft.
Hold the shaft vertically in one hand (making sure the CV is dangling inline with the shaft) and belt it with a soft-faced BFH.
Make sure there is something soft on the floor underneath everything, and keep your toes clear.
Should just pop off.
Posted 18 January 2014 - 01:16 PM
I just removed my driveshafts, and the CV joint popped free when I pulled on it with hand force.
Posted 18 January 2014 - 01:29 PM
I've occasionally had to hold the shaft in a vice and use a drift to smack the joint free. The trick is to hit as close as possible to parallel with the splines.
Posted 18 January 2014 - 03:08 PM
A vice and a hammer did the job. That thing was like glued on I think! Probably due to the milage? (56 or 156k kilometers)
