PICKUP the pieces
#16
Posted 13 July 2004 - 07:33 PM
Stripping stone chip is just about the worst thing to spend a day or two doing. At least you don't have to do it lying under the car though. Sadly coming off is the one thing it is designed not to do, and it does it quite well. I know what you mean about it clogging grinding wheels. You could try a fibreglass wheel brush on a power drill (I don't expect steel brushes will touch it), but unfortunately the best method is just to keep using the chisel and heat. It will be worth it in the end!
Good luck with the rest.
#17
Posted 14 July 2004 - 12:29 PM
Are you doing all the work yourself or getting a garage to help you out?
Yeh was a bit 'in at the deep end' dan but the pickup was already in the family and my first mini had just died when i found that the pickup existed.
M-Machine already know me well as ive had about £300 worth of panels from them already and they have lots more business coming their way.
Ive just spent all morning stripping more underseal and there is still acres more to do. Ive done the inside and outside of the floors but am struggling with the space between the floor and the loadbed as i just cant get at some places
I think this is one of the worst jobs i have to do on this project but at least you can see the difference.
#18
Posted 14 July 2004 - 04:47 PM
Wish I had a pickup, always wanted one. Very cool car.
#19
Posted 14 July 2004 - 10:14 PM
Pickups are wikid, i never thought i would find one but this one found me. Good thing really as the barn it was living in was being converted soon so it was about to be scraped
#20
Posted 15 July 2004 - 09:25 PM
#21
Posted 15 July 2004 - 10:20 PM
#22
Posted 16 July 2004 - 10:06 AM
Posted 16 July 2004 - 10:07 AM
Posted 21 July 2004 - 10:16 AM
Posted 21 July 2004 - 10:19 AM
Posted 21 July 2004 - 07:45 PM
Now all i have to do is strip all the surface rust out of the cill and put the outewr cill on then that half floor is done :grin:
Posted 21 July 2004 - 07:54 PM
before you put the outer on, what are you protecting the inside with?
#28
Posted 21 July 2004 - 08:27 PM
Anything else i should do?
what do you guys think about the vents in the outer cill? Should i leave them standard or is it best to seal them up? They were sealed up when i got the pickup, the cills were filled with expanding foam and filler had been pushed into the vents.
#29
Posted 21 July 2004 - 09:09 PM
Definitely don't block the sill vents. This can only lead to bad things. Some of the dodgier oversills have no vents punched in them, they're terrible.
The thing with leaving bare primer in the sills is that most primer is porous so it soaks up water which sits on the metal. Although I don't know about hammerite. Primer/sealer however is not. That is what I would use, or a colour coat over the primer. Make sure whatever you use is 'weld-thru' though.
There are such things as cavity waxes. I think these are slightly different to normal Waxoyl, in that they foam up to fill the cavity and last longer. But it could be just another name for Waxoyl.
#30
Posted 21 July 2004 - 09:27 PM
Hadn't thought about the primer being porous, i suppose thats the whole point of primer. Ok ill have to re think the paint stratergy, where do you get primer sealer?
