Weird Spark Plug Color.
17 replies to this topic
#1 daenesh
daenesh
  • 423 posts
  • Local Club: Classic Car Owners Group
Posted 16 January 2014 - 03:45 PM
guys i took my spark plug out to check on the mixture and i noticed that spark plug no 3 had a weird yellow color on the tip but the rest of the plugs were grey.. here a picture.. what does this mean?
Plug no 1, 2 and 4 are all grey..
#2 maccers
maccers
  • 1,867 posts
  • Local Club: LSMOC
Posted 16 January 2014 - 04:14 PM
I'd say they both look normal, maybe if anything the yellow is normal and grey is not?
#3 Rosslin Racing
Rosslin Racing
  • 2,408 posts
Posted 16 January 2014 - 04:16 PM
have a look at this site  may help you. http://totalruckus.c...hp?f=44&t=83867
#4 daenesh
daenesh
  • 423 posts
Posted 16 January 2014 - 04:36 PM
well its just that one plug being different from the others thats bugging me..
#5 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
  • Local Club: A5 minis
Posted 16 January 2014 - 05:07 PM
Swap it over after cleaning and have a look in a week or so, that way you can make sure its not down to a dodgy plug.
#6 daenesh
daenesh
  • 423 posts
Posted 16 January 2014 - 07:01 PM
thats a good idea will do it tomorrow.. but as far as it looks.. seems okay right.. not a major problem right?
#7 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
Posted 16 January 2014 - 07:07 PM
I wouldn't think so, but it is an odd colour!
#8 daenesh
daenesh
  • 423 posts
Posted 16 January 2014 - 07:13 PM
hahaha yeah thought so too so thats why i shared it for all to see..
#9 daenesh
daenesh
  • 423 posts
Posted 18 January 2014 - 05:57 AM
heres an update.. i took the plugs out and cleaned them and re-gapped them and put them back and took it for a drive and now all the plugs have turned to the yellowish color in the picture above.. good or bad sign?
#10 Dusky
Dusky
  • 5,322 posts
Posted 18 January 2014 - 12:05 PM
Has something to do with leaded petrol orso I think
#11 daenesh
daenesh
  • 423 posts
Posted 18 January 2014 - 12:13 PM
There's no leaded fuel in Malaysia.. only unleaded.. I use unleaded RON95..
#12 Dusky
Dusky
  • 5,322 posts
Posted 18 January 2014 - 03:18 PM
'Shiny or Glazed Porcelain: This occurs for two reasons, excessive idling or rich idle condition leaving heavy soot deposits. These deposits will burn and create excessive porcelain temps causing the glass to melt usually resulting in a down track popping through the exhaust..
You will usually see splotchy deposits on the plugs after the run, either green or yellow in color and of course the tell tale shiny glaze.
This glazing of the porcelain actually becomes a conductor and the spark will jump from the electrode to the porcelain resulting is a very weak small if any spark.
The porcelain should always have a chalky or dull finish.
#13 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 18 January 2014 - 03:30 PM
Yellow indicates lead fouling usually, which eventually causes a misfire.
#14 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
Posted 18 January 2014 - 03:49 PM
But it's only been run on unleaded, its a weird one!
#15 jaydee
jaydee
  • 8,565 posts
Posted 18 January 2014 - 05:39 PM
Wierd colours as shown above are due mainly to the use of fuel additives, including the manifacturer additive package.
