Mornin all
As above got a bizarre fault on my rev counter. Its a Smiths 80mm job and basically its reading about 1000rpm below what the engine is actually running at. For example on tickover which was sitting between 900 and 1000rpm it registers 0! Engine is running fine but not even a twitch on the gauge. But then as you drive or rev the engine it works as normal but reading 1000rpm below so when at 1000rpm on the gauge the engine is running 2000rpm and on right through the range. Cant for the life of me work out why. Up to this point the gauge has worked perfectly.
Wiring in is clean and all connections tight and the same at the coil etc.
Anyone got any ideas/suggestions???
