Calliper Rebfurb
3 replies to this topic
#1 philip663
philip663
  • 148 posts
Posted 14 January 2014 - 10:35 PM
Evening all
My callipers needed a replacement so i decided to do my first project thread on them so bear with me!
To minimise time the mini was off the road i decided to buy a cruddy pair off eBay cheap and rebuild them all nice new and shiny. Here’s the lovely pair I bought:
BAC3A191-D8FF-434A-B978-179C57140DEF_zps
Not so nice as you can see, the Chrome dipped rusty pistons were no greater! They shall be replaced with stainless ones =]
To remove the pistons without a compressor was a challenge. With the help of my dad we used a foot pump, a cut in half brake pipe, a nozzle jammed in the brake pipe end, built the pressure up to around 40psi and gave the calliper a persuading ‘knock’ with a hammer. Got all 4 out eventually =]
Although inside was uglier than the outside!!
0438FF07-786D-4CB2-B29C-ED27A12D00CD_zps
B7F0E68D-F476-4F1B-819D-258A86453A5F_zps
3CA3324E-1F71-4204-B803-6E60365A94A9_zps
F64D1E98-C498-42C6-AB6D-918DCFE95B33_zps
But that wasn’t anything that a few dozen wire/brass dremel brushes couldn’t sort out:
69683358-D2C3-4886-B336-3482652E8354_zps
Once id made sure the grooves were completely clean and smooth i polished the insides with alu polish and it came out nice and smooth, it’s like the metal is stained from the rot!
Progressed on to sorting the callipers out for their powder, taping inside and blocking off any holes:
88E2ABB6-2F81-4355-8267-E62137F6F68F_zps
558C2544-2CB4-4F70-81E8-E1DD3B11B819_zps
04F6AA09-4602-422A-BD34-03C9CD6CEE0E_zps
Back from my friend and wow, they are like new!! Smooth, nice to touch, no more rough patches, I’m chuffed!
923383_406332299489359_1059560216_n_zpsf
EA46E435-711E-4853-A1E5-031B03CC1E7C_zps
16687DB6-A439-4353-9B7E-CD80412F1215_zps
84E69655-9706-4CAA-9B76-6F19F39FDD30_zps
Nice, real nice!! So i split the calliper back down to fit the pistons easier and of course the inner seal:
28E808D7-D0CB-4B34-B80F-E840C8371CDF_zps
05BE5BF5-9E54-47E3-B622-1D2ADCDCB3DF_zps
BD623836-1783-4DB2-8A68-5A7C9570CDCD_zps
This turned out to be a pain in the arse in the end, two sets of dust seal rings later i had them done! I eventually opted for the plank of wood approach and a vice, worked in the end that way for me:
B0C8A5B8-AA9E-4595-9635-F9BD2D42F4EF_zps
2A480EFF-4F31-4F38-960C-3EE05F377D45_zps
C53F4073-47B2-442C-B7DD-10A66B1E133A_zps
Some nice titanium bolts to add to the nice powder!
A4AB660E-150C-4D93-AC71-3E67A9ACD337_zps
Now to put the callipers back together!
FF8A0794-FA75-4969-9853-2FFDD3538062_zps
BF34DA63-CA37-4864-B98A-07EDD9268517_zps
Nice..
I Torque them to 50 ft lbs which seemed pretty tight for me, same as a cylinder head!! Loctite used of course
Putting them on the car was the next step, mornings work including new disks! Out with the old, in with the new:
1B5F2FD3-F8F2-4452-8D45-4F2F3CA7EFCD_zps
1C40FFC8-C2B3-4B07-A04E-2ABA0FFA938B_zps
0B611CFC-59AE-4F6A-B8BC-76EA191A91BA_zps
5B067FE5-F970-43C4-9051-341DF5E023FA_zps
Nice, just nice =D
So costing:
£10 for the callipers
£38 on stainless pistons
£5 for my ******* up with the seals
£15 titanium bolts
£3.77 on nipples and inner seals
£15 for the blast and powdering
Brings it to the grand total of £86.77
Which comparing it to minispares calliper if i were too of bought new for £124.80 means i have saved £38.03 by doing the work myself, plus the satisfaction that i have done it myself, they are red and have titanium/stainless parts.  (Yes the 5bhp extra i have gained through them being red!! Is true in my opinion as the car doesn’t drag anymore and the wheel spin freely!! Woo)
I also plan on recouping some of the cost back through cleaning, blasting and powdering my used callipers and selling them on to bring down the cost of the new set so hopefully it shouldn’t of cost me that much for a ‘new’ set of front brakes =]
Hope my first project thread wasnt a bore, radius arm one to come next!
Phil
#2 cooperdan
cooperdan
  • 3,729 posts
  • Local Club: N/A
Posted 14 January 2014 - 10:40 PM
Niceeeee ;-)
#3 Carlos W
Carlos W
  • 10,115 posts
Posted 14 January 2014 - 10:42 PM
The callipers look great, but be careful spending loads on the set you're going to sell! You may not make your money back!
#4 myredmini
myredmini
    My Mummy Says It's OK
  • 3,211 posts
  • Name: Dan
  • Local Club: BOG MOG
Posted 14 January 2014 - 10:46 PM
Very niceee!!!  :thumbsup:
