12" By 6" Alloys With Group 2 Arches?
Best Answer IainNeon91 , 14 January 2014 - 07:54 PM
My mates mini with 12x6 superlights and group 2 arches:
My mini with 12x6 superlights and group 2 wide arches:
Hope this gave you an idea of the clearance and look
Go to the full post
6 replies to this topic
#1 minirelatedname
minirelatedname
  • 29 posts
Posted 13 January 2014 - 05:22 AM
Hello
So i have a set of alloys and they stick out around 6cm or roughly 2.3 ish inches, group 2s measure 2.5" at widest point so I think I could get away with it. The advice that I would greatly appreciate is, would i have any clearance issues and is there anything else to be concerned about?
Thanks in advance
#2 Will16
Will16
    Wants a custom member title
  • 1,090 posts
Posted 13 January 2014 - 07:37 AM
Group 2 should be fine. You may have to cut your front wings slightly. Have a look here-
http://www.theminifo...or-12x6-wheels/
#3 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 13 January 2014 - 07:46 AM
you normally need something wider for 6 inch alloys
i'm guessing yours are 5x12 and your measuring the outside of the wheel rather than where the tyre sits
#4 hustybusty
hustybusty
  • 236 posts
Posted 13 January 2014 - 11:47 AM
I have that setup and although borderline I consider to be fine, certainly look reasonable if you were to be pulled. I didn't cut arches and they rub on full lock
#5 cal844
cal844
  • 9,611 posts
  • Local Club: TFMOC
Posted 13 January 2014 - 12:29 PM
my 1275 rubs on certain corners (in car parks mainly) but only the drivers front wheel :X
#6 IainNeon91
IainNeon91
  • 1,287 posts
Posted 14 January 2014 - 07:54 PM   Best Answer
#7 minirelatedname
minirelatedname
  • 29 posts
Posted 25 January 2014 - 04:19 AM
Nice one mate, thank you for that
P.s. that is a gorgeous mini
