mayo under oil cap
8 replies to this topic
#1 barlos
barlos
  • 16 posts
Posted 29 May 2006 - 05:48 PM
on toping up the oil i notice the dreaded mayo under the cap, what would be the most probable cause of this and what would cost to put it right?
#2 big bad dob
big bad dob
  • 64 posts
Posted 29 May 2006 - 06:02 PM
head gasket is you problem.ot should cost you pence if you do it yourself but could pay abit if you take it to a garage
#3 Big_Adam
Big_Adam
  • 7,435 posts
Posted 29 May 2006 - 08:10 PM
as big bad dob says head gasget probly. just get a new one. wip the head off change the gasgets over plonk the head back on. simple........apart from all the seased bolts. the exsaught that won't move and all the other parts of a mini that make a job difficult.
XD
#4 minimole
minimole
  • 781 posts
Posted 29 May 2006 - 08:20 PM
It might not be your head gasket. it might be condensation. check your dipstick for mayo as well also try and check you cooling system for desposits of oil in it. also do a compression test.
if there is mayo on your dipstick/oil in your cooling system then i would say that your hg needs replacing. however do a compression test. this is probally the best way to find out if you hg has gone.
#5 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 29 May 2006 - 08:54 PM
Was this just after a very short drive, or before driving at all early one morning? That would normally just be condensation. If there's still mayo there after a longer drive then there may be a problem.
#6 clubman katie B.F
clubman katie B.F
  • 1,524 posts
Posted 29 May 2006 - 09:54 PM
i concur with the above opinions.....have you checked the compressions on all 4 pistons?
#7 cooper_shaz
cooper_shaz
  • 1,000 posts
Posted 30 May 2006 - 08:00 AM
As above, does not always mean head gasket, engine flush and an oil change are the way to go first.
If you are changing the oil yourself then fine if not then go to tthe garage whenre you are goign to get it changed, just before they change it, Clean the cap thoroughly and use an engine flush, add this to the oil and let the car run at 2000 rpm for 20 mins or so.
Then get the oil + filter chaged, see how this is and if you stil get mayo after a day or so..
Best not to drive the car with the engine flush in there as the engine oil is also gearbox oil and the flush thins it down.
#8 Jammy
Jammy
  • 25,397 posts
Posted 30 May 2006 - 08:06 AM
Have you been eating a sandwich over the engine recently?
#9 minipip
minipip
  • 1,591 posts
  • Local Club: TMF SE
Posted 30 May 2006 - 11:33 AM
any lumpy bits with a hint of yellow, dam egg mayo is gooodo
