Classic Mini Rover Morris Austin Aluminium Radiator
6 replies to this topic
#1 salient
salient
  • 29 posts
Posted 11 January 2014 - 09:39 PM
Do any of you members have experience of using the above aluminium radiator as ebay item 111255202788.
Seems to be made in China so want to be sure it won't leak under pressure and will cool better than standard unit.
thanks
#2 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
  • Local Club: A5 minis
Posted 11 January 2014 - 09:44 PM
I have used ones I got direct from china (sellers name is winner racing on eBay). I have had four now for several years with no problems. One was pressure tested back to back with a Radtec one at Lola cars ltd a couple of years back and both took double the pressure that the cap releases at.
#3 salient
salient
  • 29 posts
Posted 11 January 2014 - 09:55 PM
thanks Clive, sellers name of ebay item 281242258122  is wr_manufacturer so could the wr mean winner racing?
thanks
#4 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
Posted 11 January 2014 - 10:08 PM
This is the one:
http://www.ebay.co.u...=item1c3555b87b
Only problem I had was one arrived damaged due to bad handling, it was replaced within a week no questions asked.
#5 GreenMini17
GreenMini17
    Formally known as Chris-G
  • 424 posts
Posted 12 January 2014 - 08:28 PM
Although they are cheap and as people have mentioned above that they will most likely preform as well as a uk made one, i would never even bother. For the sake of an extra £60 i would buy the thermex one from minispares. Mainly because of the fact its uk made (and all us mini owners like supporting british made products) plus if there is ever any fault with the rad (for example it does explode) then you have a direct contact in this country that you can call and explain your situation to. Thats my angle anyway.
#6 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,033 posts
  • Name: Neil
Posted 12 January 2014 - 08:34 PM
Before this descends into a "who's is best rad thread" OP have a look at these threads
http://www.theminifo...nium-radiators/
http://www.theminifo...ese-alloy-rads/
#7 salient
salient
  • 29 posts
Posted 12 January 2014 - 10:42 PM
Thanks for all your comments but I am a little confused on how many cores is best, irrespective of it being made of aluminium or copper. Some are also described as 2.75" presume width but not sure how many cores.
I would like to select a side fitted rad that is cooled by the spi electric fan to cool my 1330 for road use. Don't really want to waste power by having the mechanical fan running all the time. Any further thoughts?
thanks
