im quite new to the tuning game,
ive got a 1275 sprite, i recently changed the spark plugs and the old ones were white indicating that the engine was lean.
so i fitted a AEM sensor and gauge (which i had been eyeing up for a while) to possibly help me tune the car
took a drive and it was indicating high 15's 16's (the gauge does tent to bounce about a bit)
started ritchening the mixture and ive got it to the point where i put my foot down its nicely sits mid 12's 13's it also sits like this if i'm just cruising (not going past 2000 RPM)
however when i get up to 65-70 and stop accelerating it drops right down to 16's 17's
is this normal? because i have stopped accelerating it reads lean??
i would have thought it would have stayed around the same mark roughly
ive got the standard carb Hiff38 i believe
with a richer needle the garage fitted for me after i fitted my ram pipe and straight through exhaust
and the sensor is fitted just before the gear stick
Thanks for reading this if you did ;)
Mark
