Hi All,
Have just come across a bit of info on the Mini Spares web site regarding combustion chamber volumes. It states all 1275 heads left the factory with a volume of 21.4cc
does anyone know how accurate this figure is, and were heads produced consistently to this spec.
Only reason I ask is because I recently measured the volume of my head and it came out at 22.5cc, so I have just measured out 1cc of fluid and it isn't a lot so I would definitely question the accuracy of the measurement I have taken.
This 1cc difference makes quite a big difference to the compression ratio something like 0.3 in my case, and on top of this the head has had a minimal skim to clean it up so the compression ratio figure for my engine worked out using the figure 22.5cc is almost exactly 10:1 but using the figure of 21.4cc it works out to 10.3:1 and with the minimal skim the ratio would be even greater.
Anyone have any thoughts on the figure of 21.4cc and its accuracy?
Hope that lot makes sense.
Stuart
Edited by Stu1961, 04 January 2014 - 10:26 PM.
