Job done, but what a miserable experience. Several days of penetrant soaking and chisel work was to no avail. I tried cooking the area with a propane torch, eventually setting one cone on fire. Still no success. I finally used my 7-1/4" circular saw to make a circumferential cut in the cone just above the trumpet. I cut through the rubber and the inner aluminum ring. I then put the trumpet in my vise and chiseled the cone remnant from the trumpet.
I removed the ball without too much difficulty. I used penetrant and then heated the mating area using a propane torch. I fixtured the trumpet wide side up in my vise and pushed the ball out with a hammer and a 5/16" steel rod.
The trumpets are now cleaned up and ready for reassembly.
The good news is that I'll be a trumpet expert when it's time to redo the front cones!
DSCN4756.JPG 67.33K
10 downloads
DSCN4755.JPG 58.13K
18 downloads
DSCN4754.JPG 64.16K
16 downloads
