Hello and happy new year everyone!
A problem arose with my Mayfair on N.Y.E and hasn't gone away.. It's started to lose power and stutter when accelerating at low speeds (e.g. 1st/2nd gear) especially up hills, but not always so I;d class it as intermittant. Once it gets some momentum behind it it's fine. I can get to motorway speeds and has plenty of torque while there, it's just speeding up from slow where I have the problem.
Also if you keep your foot on the gas when it's mid-stutter it will backfire (think it's through the exhaust but not 100% sure). It also seems to make a loud pop noise sometimes if you floor the gas for a moment and then ease off suddenly.
I checked the timing tonight and it was well out. Strange because I haven't touched it. At 1500 RPM and with the vacuum hose - which is working perfectly - disconnected and plugged it was reading off the scale so I moved it to 8 degrees BDTC. This hasn't made much difference, a little but not much.
The car is a 1991 Mayfair 998, completely standard except for Powerspark electronic ignition.
It's not the dashpot as this is topped up. I've been told it's probably the weather (car is used to being garaged but hasn't the last few weeks) however I'm not convinced as it's never been like this before in the wet and the dizzy and rest of the engine bay is dry.
Any ideas?!
