92 City, My First Rebuild.
roundnose
670 replies to this topic
#451 big-jay
big-jay
  • 518 posts
Posted 07 December 2014 - 09:13 AM
quality!
Cheers ben !
#452 Steve220
Steve220
  • 5,044 posts
  • Local Club: BMC
Posted 07 December 2014 - 10:53 AM
Jay,
That steering column bracket looks the nuts! Where is it from?
Still a fantastic effort by the way, properly built not bought!
#453 big-jay
big-jay
  • 518 posts
Posted 07 December 2014 - 11:21 AM
Jay,
Cheers Steve,
I got the steering bracket from here -
http://www.kiddspeed.bigcartel.com
He's also in the traders sections on here.
Jay.
#454 Chris1992
Chris1992
  • 2,022 posts
Posted 07 December 2014 - 03:38 PM
this is an epic build!
loving the wheels, and all the stainless stuff is to die for!
keep an it man  ;D
#455 big-jay
big-jay
  • 518 posts
Posted 07 December 2014 - 04:41 PM
Update,
Well today didn't go as planned unfortunately. I jacked the car up and removed the passenger side wheel only to find the new cv boot fitted a couple of weeks ago had a small split in it -
6b776ebc68195b2f90ee7bcfe0cfa00f_zpsdaf3
Now, I'm not sure whether this happen'd when I was fitting it or if it was already there. Luckily though I had a brand new spare one.
So, ended up having to remove the whole hub assembly until I was left with this -
5da8a5c75d8ca7798b990de3ac1f85ca_zps626e
Wrestled the cv joint off the drive shaft and replaced the rubber boot -
7c0040aa98f7b1fcc74c208be0a01a16_zpsd090
And refitted the cv joint -
5ee7a9fe85042fc2e756abc0d3bd61b2_zps4642
I also noticed I didn't fit the white platic dust shield over the oil seal on the back of the hub, so I dug that out and fitted it -
d407513eee14480409be73feadfd041c_zps923b
So with the hub back on, we started on the job I originally intended to do, fitting the brake assembly. Screwed the drive flange to the disk -
e4343d0d6edf0752a5511e44bd6c5e98_zpsbfac
Placed that assembly onto the shaft and torqued it up using the flat washer tool from minispares, here it is -
b543657d3939028dedac520b409e9089_zps5152
Took that back off and put the hub nut split washer on, then torqued that up and put the split pin through the whole and bent it around -
2d4553dc225cd5da7875720270de5ade_zps7734
Fitted the caliper and the braided hose -
0c5e3981074603327428040ab8210f1f_zps3492
And then put the wheel back on, took a picture through the headlamp hole, looks the nuts -
f327866719c9435f2d7d550843a15e18_zps5bd3
Started getting dark so we didn't have time to do the other side, but I did fit my bonnet catch assembly with the stainless bracket from Smiffy's -
f415cf4333cb9ce09b70687f5595cbfe_zps12ae
That's all for today, but I may get the drivers side done tomorrow, weather permitting of course !
Edited by big-jay, 07 December 2014 - 06:26 PM.
#456 big-jay
big-jay
  • 518 posts
Posted 07 December 2014 - 04:51 PM
keep an it man  ;D
Cheers buddy !
#457 Jared Mk3
Jared Mk3
  • 1,974 posts
  • Local Club: MOCKZN
Posted 07 December 2014 - 06:47 PM
Those brakes look so good on there!
#458 big-jay
big-jay
  • 518 posts
Posted 07 December 2014 - 07:37 PM
Thanks Jared,
I have to agree, i think they look amazing !
#459 ToM 2012
ToM 2012
  • 4,066 posts
Posted 07 December 2014 - 09:45 PM
Looks fantastic! Well done mate keep up the good work cheers Tom
#460 big-jay
big-jay
  • 518 posts
Posted 07 December 2014 - 10:21 PM
Thanks Tom !
#461 mark-stranraer
mark-stranraer
  • 62 posts
Posted 08 December 2014 - 05:14 PM
just sat for the last 2 hours and read threw the whole thread.
Mint!! top job keep up the work :highfive:
#462 big-jay
big-jay
  • 518 posts
Posted 08 December 2014 - 05:29 PM
Cheers buddy !
#463 mark-stranraer
mark-stranraer
  • 62 posts
Posted 10 December 2014 - 09:28 PM
Cheers buddy !
did you powder coat front hubs or is it hammerite or what ?
looks mint
#464 big-jay
big-jay
  • 518 posts
Posted 10 December 2014 - 09:37 PM
Cheers buddy !
looks mint
Cheers pal,
Ive had all of my running gear powder coated.
Edited by big-jay, 11 December 2014 - 12:05 AM.
#465 José Cardoso
José Cardoso
    Just On Tickover
  • 6 posts
Posted 11 December 2014 - 03:38 AM
Fantastic job :-)
The front brake discs are assembled in the wrong side, you have to change the disc from left to the right, and the disc from right to the left.
