92 City, My First Rebuild.
roundnose
670 replies to this topic
#406 big-jay
big-jay
  • 518 posts
Posted 15 November 2014 - 08:19 PM
Stunning job as always Jay. Normally I'm not a fan of red on red, but this just works  =] Keen to see how you get on with the headlining.
Cheers Jared !
#407 megamini_jb
megamini_jb
  • 5,491 posts
  • Name: Jamie
Posted 15 November 2014 - 08:23 PM
Loving the splits! And the red engine looks so cool in a red car!
Sweet build!
Edited by megamini_jb, 15 November 2014 - 08:24 PM.
#408 Stu.
Stu.
  • 912 posts
Posted 15 November 2014 - 08:49 PM
Looking mint Jay :)
#409 big-jay
big-jay
  • 518 posts
Posted 15 November 2014 - 09:01 PM
Sweet build!
Thanks Jamie, I must admit, I wasn't to sure about a red engine in a red car, but now it's in i think it looks great !
Looking mint Jay :)
Cheers mate :-)
#410 big-jay
big-jay
  • 518 posts
Posted 16 November 2014 - 06:09 PM
Update,
A bit more done today, the headlining is now fully fitted and I'm really happy with how it's came out. Here's a few pictures of how we fitted it.
This is how the Headlining looked around the C-pillar before we started -
d4db29a5ce4f40502b7d484e65097156_zps5944
We trimmed the bottom off so it's straight -
ecadde516a85517171d7a0681561c460_zpsccf6
Then we glued the rear and side window flanges and the back of the Headlining. We left that to go touch dry and then literally just stretched the fabric until there's no creases, then stuck it down and placed some old boot rubber on to keep it in place -
524261438cf69af50802ddced03ddbfb_zps3f90
That's literally all there is to it. The same process applied to fitting the headlining around the side window, started off with this -
85e2aa8b63368e26ba966852a40a183f_zpsbd42
Glued and then stretched into position -
13fb56665c5ea83b89618c371e9bb007_zpsda85
Now onto the more tricky B-post, we trimmed it to fit around the flanges like this -
4baf63bc663af6e125bd798efb1f776e_zps808b
Apply some glue and pull the fabric around each flange and you end up with this when the rubbers are fitted -
aa84d898d7f646be618c45f0bb2595ce_zpsfb7c
Here's the other C-pillar finished -
d8c098ebec5cbc5f783fedcc60ba4946_zpsbb88
The other B-Post with the interior light fitted -
3382e1bc375e90f76a8f2c293425f324_zps61de
And a few overall shots of the finished thing -
7c8788c8a295020984861709e1d4d9e8_zps4029
54c1f92dff347daa6d1c3f5178ee6d2e_zpsbf80
917df234e87600a5b21c6266fca20011_zpse350
711ad43ea1150d378428e3af1d20dca7_zps81ba
0006fb9d714d253870001479b1855d1d_zpsad20
We also fitted the little bit that goes along the parcel shelf -
70ea73836b15c1f57ae9e45f58d58769_zps12c6
Happy with that I built up my boot lid and got that fitted -
e6d4826d22e82655a032b5c33bd4780a_zpsf065
45bc1309980e2ff19461a6d4f704762b_zpse7e0
0b07fe3cbc9d39a1f5e01d9a29fc21e3_zps0f42
0b5842d74288d77469821d649d8af519_zps8fe4
00e44292b00a61d2b648434f99ffb18b_zps8744
That's all that's been done today, I think the next job will be to get the sound deadening down so will make a start on this tomorrow !
#411 Stu.
Stu.
  • 912 posts
Posted 16 November 2014 - 06:33 PM
Like a pro Jay. Looks really good. Could I ask what glue you use to bond the material.
#412 big-jay
big-jay
  • 518 posts
Posted 16 November 2014 - 06:55 PM
Thanks buddy.
You certainly can, this is the stuff we use -
http://www.amazon.co...8/dp/B0001P03S8
And also -
http://www.amazon.co...l/dp/B00HVG6BHW
#413 Jared Mk3
Jared Mk3
  • 1,974 posts
  • Local Club: MOCKZN
Posted 16 November 2014 - 07:08 PM
You guys really did do a stunning job of that rooflining - I hope mine comes out at least half as good. I suppose once a you get into a rhythm then it gets easy. Just one question (and probably self explanatory as well), did you pull the lining in all directions, but making sure to keep it centralised? Also, do you recommend starting with the front or rear of the roof?
Great job as always  =]
Edited by Jared Mk3, 16 November 2014 - 07:08 PM.
#414 big-jay
big-jay
  • 518 posts
Posted 16 November 2014 - 08:21 PM
Thanks Jared,
It does get easier as you go, it's making the first cuts in the lining that are the most nerve racking !
Yeh, that's all we did, I pulled the fabric downwards to remove the creases and my dad pulled either side tight and stuck it to the flanges.
We started by tensioning the front and glueing that down, then round to the back and done the same thing there. Then it's just a case of doing the sides. It looks a pretty daunting thing to fit, but it's not really to bad if you just take your time. We done it over the course of a month doing bits at a time really !
#415 Steve220
Steve220
  • 5,044 posts
  • Local Club: BMC
Posted 16 November 2014 - 08:25 PM
Excellent work getting her back together Jay!
As a side question, what sealant did you use when you assembled your rims? And what torque did you do the Allen bolts upto?
#416 big-jay
big-jay
  • 518 posts
Posted 16 November 2014 - 08:33 PM
Thanks mate,
I haven't used any sealer on the wheels. I did the studs up tight with an allen key and then another half a turn with a ratchet and an attachment. I don't think there is a specific torque setting, I maybe wrong though ?
#417 Steve220
Steve220
  • 5,044 posts
  • Local Club: BMC
Posted 16 November 2014 - 08:50 PM
It's supposed to be around 16-20lbft. I always thought you had to seal them once they're together to prevent air escaping through the gaps and causing corrosion.
#418 big-jay
big-jay
  • 518 posts
Posted 16 November 2014 - 08:59 PM
Ahh, will drop the guy that done the conversion an email to confirm a torque setting, thanks for letting me know !
They've got inner tubes in mate so I shouldn't have any problems with air escaping.
Edited by big-jay, 16 November 2014 - 09:52 PM.
#419 Jared Mk3
Jared Mk3
  • 1,974 posts
Posted 16 November 2014 - 09:43 PM
Thanks Jared,
Really appreciate the assistance. Will definitely be going back to have a look how you did it.
#420 big-jay
big-jay
  • 518 posts
Posted 16 November 2014 - 09:51 PM
No probs Jared, happy to help !
