92 City, My First Rebuild.
roundnose
670 replies to this topic
#226 big-jay
big-jay
  • 518 posts
Posted 31 July 2014 - 04:08 PM
Update,
Some more progress on the doors today, here's a few pictures.
Left the Deox Gel over night and it's worked great as usual -
f0ba66d22403c20bc58c8f8039c94219_zpsd5d2
9cf8926d13066a0919e26193858a9ecf_zpsa6ee
Wire brushed the frame and then wiped off the Deox Gel. Then applied a few coats of zinc primer -
969d83f7c8b0691184406351c34d0544_zps265c
Flipped the frame over and removed the Magnum black paint from the front. Sanded down the flanges and then zinc primed it -
7c3a4877310263328468a8063053c28b_zps8316
b064d806e6d11c7a59a4e59b0f46711d_zpsf766
6130122ab130ee39a5138ddcb8fbc9ba_zpsc0f6
Placed the frame into the skin, positioned it roughly where I wanted it and then closed the edges of the door skin over the frame -
7c296cbe9e1cb04e19f69ff2995b5500_zps943e
Took it out to the car and bolted it to the A-post, gaps aren't too bad for an initial fit -
fd56b413174ed7a95464c80768810922_zps8dd5
159c2e9e57ffacd9d8bdbdf42e346cae_zps7629
Drivers door -
e50dc74a18983d0f3f67b60f1efe85ad_zps1fe2
40852751c7369002375b5d9c008f7a5f_zpsea5b
Both still need more work and I've bought some weld rods to get the gaping right. This is where I'm going to spend the extra time because if the gapping isn't right then it'll ruin the whole look of the car. I haven't welded the passenger side door skin to the frame yet though, so I've still got room to manoeuvre that about.
I'm going to set them more or less where I want them for now and then I'll come back to the door gaps after I've got the front end on, should be the last job to do before it goes off for paint !
Edited by big-jay, 31 July 2014 - 04:17 PM.
#227 big-jay
big-jay
  • 518 posts
Posted 03 August 2014 - 07:45 PM
Update,
We've been having a play with fitting and lining up the front end for the last couple of days, it's all starting to come together now and the gaps are looking quite good so I'm fairly pleased !
Anyway, here's a few pictures.
Fitted the front subframe back to the car, for the first time in almost seven months, using all new mountings -
f3130da4ac222af91a094f19c3098b4d_zps56e6
Then we fitted the bonnet and adjusted the gap to the scuttle -
e87583271a1ce9df84d9c430afb2744f_zps9e58
04e94bcb45cc1263dc1448b38d4a4f23_zps95b6
Fitted the front panel and adjusted it until it sat nice with the bonnet -
e65e00603d735c5c63842d368d8d48bd_zps6549
9ec1f4081e6520488940ceb6aea884b7_zpsaea9
6c7ec8933f99a7ee52f4d30b5e74d651_zps9f98
Then it was onto the wings which proved to be a lot more tricky. Took a few hours to wrestle them into position, but the gapping has come good thankfully.
929c9def36acfc8c798fcfd03003edd9_zps87fb
02828639e6c19e1715ddcfc6ac47338e_zps3cff
157ffdc7007e20c4f69d101b848484a1_zps08d8
So that's all clamped into place but will still need a touch more fetteling before we're 100% happy to weld it in place. Still got the A-Panels to put on and line up but that's a headache for tomorrow !
#228 Jared Mk3
Jared Mk3
  • 1,974 posts
  • Local Club: MOCKZN
Posted 03 August 2014 - 07:52 PM
Some really nice and even gaps there, looks neat. Keep it up.
#229 big-jay
big-jay
  • 518 posts
Posted 09 August 2014 - 07:36 PM
Thanks a lot Jared !
Update,
Well I've put my two week break from work to good use, I've now got a complete front end on the Mini.
Carrying on from my previous update, I went around the front end panels and tweaked them until I was happy with the position they where in. Then I went about drilling all of the holes required for plug welding.
Wings -
a7889674e775efc7ebb3434a79f2b0a6_zps41ce
baa895e4a69b7eba2f903915fdf219ae_zps8089
Front panel -
d460176a6bb90db2ed080749c56f2a61_zpsed36
d73ab8b1087f28cb35e69406b4784ffa_zps8a85
Clamps required to hold the wings and front panel in position -
6d1a2d5c5c151792905b814bb1a9194b_zps88e5
7f85feafd3c8ac8447414e4db9a69a22_zps0174
How that looked from the outside -
0ab40cd7b87e95f2fd2b7f68661fa5a8_zps27df
a5df44e1bee9cfe56e84fb7db16ca998_zps2963
All welded in place -
b31645cfb07baa02879198060882f4c4_zpsb1eb
15aeef652763384283b151aefdd81bc4_zps6616
6f3f3ad7068b17c32d26193fead5aac9_zps4a3e
ada1bfad0199e3a31bd3488e4fc65290_zps31a2
Completely welded the wing to front panel seam to minimise the risk of corrosion -
f5565d30c20f8ee5bb02fdcc1ebf8cae_zpsa1d7
6dcd057428dabf0113daaecdf19b6576_zps8ca6
Also had to redo a few of the spot welds Magnum had done on the front panel as they hadn't caught at all -
937401d74cf6f4b9fe26352100f68854_zpsc142
How that all looked with the bonnet placed on -
343cbb1754a0de01ecf00e43378610bc_zpsecb4
Next up was the A-Panels, zinc primed the door post -
71632d66bbda79a6ea8b7d78e80501a2_zps3c88
Zinc applied to the A-Panel -
407dbf80963d2e059e34fcd740e0d27f_zps878b
Clamped into place -
23c43c93d6c53631f61e6de9cacd6d66_zps8857
And then folded the lip over using the method shown on this forum, which involves the use of mole grips and a piece of wood. Came out really well -
776281291856160639b2e9c3cb4190a1_zpsd638
Exactly the same procedure for the other side -
8dfaa434a5d9e9a9dabc3c6514ce39b4_zps7958
Overall look -
101e291af73abd38e9336da5da599968_zps5ce4
10f6aab3708e1d68840afd1affb3d8ab_zps59e3
Also gave the welds on the wings a quick grinding down and applied some zinc primer -
e6af7cdb32026a42904ea7cf40431be3_zps6c3c
e045ed7c2ece9d8cdfe8d279a0243b88_zpsf904
Still not finished with this as I've got a lot of grinding, priming and sealing to do, but at least i now have a complete Mini ! (sort of)
Anyway today we decided to have a look at the door gapping's on the drivers door.
Door to rear quarter -
3b891f5dff1c35f321459a3c52b1c4a9_zps8455
Door to A-Panel, hard to see in the picture as the A-Panel is still in the black E-Coat -
20aac5dc3b01e2a40f96e8353c41688c_zps6dc6
Not brilliant and much to wide for my liking, so we marked out where the problem areas where and tacked welded some weld rod to the door -
43bc2d8ca3a77b6371d2d9a9d3290863_zps55af
6df4ddc4ffc307e3e7593c1a2dccc425_zps7262
Happy with the general position they where in we took the door off and fully welded the rod to the door front and back -
31b5999ae486f9728fb1184e61eb169a_zpsa217
de6b18ed90f1a9a6a9aa6a15750daba7_zps23d7
d9774dc244092fdfdcc0c6c246559e5b_zpsca5d
After a quick grind down and a bit of shaping -
8cf6621dee3b95a15dbb3fd4fb477ccb_zps0d62
3f2b90067363468614f86c66a17942d9_zpsd5fc
Bolted the door back to the car and we now have this, not 100% finished as I'll still need to tweak it a bit, but a vast improvement non the less -
50dd83a9fcc822f0739474dd2c76c2ff_zps6618
(Again hard to see as the A-Panel is black, will apply some grey primer tomorrow and take a picture, so you'll hopefully be able to see the gapping a lot easier) -
94dec3a4c6c9253de3ad6e97b75d75a1_zpsa062
Not to much left to do now, just the passenger door gaps to sort and then all the tedious jobs like sealing and what not.
We'll be phoning the place that's going to be painting her on Monday to book her in, probably looking around the middle of this month so that should give me enough time to finish the last few jobs !
#230 deepee71
deepee71
  • 101 posts
Posted 09 August 2014 - 07:43 PM
Super work !, must have great neighbours?...I used to have to work outside before we moved and have a garage. The problems it used to cause with the exposed noise etc....
Andy
#231 big-jay
big-jay
  • 518 posts
Posted 09 August 2014 - 07:54 PM
Andy
Cheers andy,
To be fair, I haven't had a problem thus far, seems a lot of them take a genuine interest in what I'm doing. Helps that I work nights too so when I'm up in the day there usually at work.
#232 domdee
domdee
    Formally known as dominicdee
  • 1,183 posts
Posted 10 August 2014 - 07:02 AM
them gaps are looking great
#233 big-jay
big-jay
  • 518 posts
Posted 10 August 2014 - 07:13 AM
Cheers bud,
Definitely worth that extra effort to get them looking good !
#234 big-jay
big-jay
  • 518 posts
Posted 15 August 2014 - 04:09 PM
Parts update,
Received a big package from Force Racing today, I wonder what could be in it ;-) -
a35a38e230a31d1dca0d490d06b46b8e_zps8489
440fee5f938d0cd591349f9e2ff46f55_zpsb82b
My long awaited Exacton split rims, they look absolutely stunning, and will look even better when I've had them blasted + powder coated.
Here's a couple more pictures -
5bf0e9ec46ee3489f9cf7df8ff928492_zpsf3fb
d60624810b9eb9845d893206baf176be_zps7b3e
094e9239797337715c029017ef6493ef_zps7442
c99408c071d3cac8373bd1b3d6c1d125_zps487a
6c0ace9eea8d0411befdce05b0398b77_zps0f2c
An absolute credit to Carl at force racing, he does a cracking job !
The paint shop will be coming to pick up the Mini next Saturday, so it's going to be a busy weekend getting all the small jobs finished off so she's ready. It'll probably take them around two - four weeks to completely paint the shell so that should give me time to get all the running gear and what not refurbed and painted.
#235 Jared Mk3
Jared Mk3
  • 1,974 posts
Posted 15 August 2014 - 06:36 PM
I really want a set of these  :(
#236 big-jay
big-jay
  • 518 posts
Posted 21 August 2014 - 07:13 PM
Update,
Well the Minis off to the paint shop on Saturday, so I've been doing all of the small jobs that are required to make sure she's ready, lots of sealing, bits of fillering and a few welds here and there. Nothing too interesting so I didn't take too many pictures, but I'll put up what I have anyway.
Completely welded the scuttle flange to the wing/a-panel flange -
c82edaa3d08b876e77fc0f64b70dd051_zps3cfc
b5b880a391b8ef39b17c63890385bc8a_zpse1c1
Had some extensive pitting around the fuel filler neck, so had to replace that with fresh metal. Cut out the rot -
445dbc15bdd2fab6e8fcf4824bd7a23e_zpse817
CAD template made and transferred to steal -
a7c364d6efd46068682c9a2221d36570_zpsd646
Clamped in place -
ef4bf6783a80c719106d28dc3d19d7fb_zpsf5a8
Welded in and ground down -
852f909084dec34ce0d065588e0efe48_zps5bf6
Tried the rubber seal for fitment-
2eb54b334d8357edd91f91c6e1d303d9_zps0706
Cleaned up and welded the bonnet stay bracket back in place -
559c8435c7d3599319d837bd9c8af22e_zps537e
cffcf919b2f907b8050e9f9587b58a85_zps705f
Welded up the holes in the bonnet as I'm going for the clean, de-badged look. Still needs going over with the power file to make it completely smooth, then a lick of filler to finish that off -
c27aed1f5b79e9241f74bccd5c5098f6_zps800b
ef8a6f164146e947a563fba926dd5386_zps6699
Lots of sealing done underneath the wings -
7a1711624855cac4b8fe12a6704292d1_zpsec42
c762ae60a6b93fa28ec4e0e44786bef2_zpse2ec
5c29e419cad8d20acde909fb8332b52c_zpsf810
Same was done for the other side, that's just a small portion of what we've been doing, but as I said, it's not very interesting so I haven't been taking too many pictures. Still got more sealing to do tomorrow so will put some more pictures of that up when I've done it. I've also been doing more work on the door gaps, I should get that finished tomorrow so they'll be some pictures of that too.
Now onto something a little bit more interesting, I bought some new hinges from Minispares recently but I found them to be pretty poor if I'm honest, so I decided not to use them and to try and get my original ones repaired, as they had a fair amount of play in them.
So we went down to our local engineering shop to see about getting them reamed and having new pins put in.
I had the holes widened to 7mm to eradicate the wear in the hinge, bar the last section which was left at 6mm to ensure that the pin would not drop through as it wears. Then I had some new pins made from solid hardened steal, these where machined to 7mm, with a 6mm taper at one end and a rolled edge at the other so it will grip tightly when pressed into position.
Here's a few pictures to better explain.
51391bba15f7130b33b9759e2a5a2659_zps922d
1e987d8184fa0df3d8d10b2d03dd8369_zps398a
As you can see, the bottom hole, of the part of the hinge that screws to the door, has been left at 6mm, the rest has been machined to 7mm -
Here is the pin, note the step at the bottom -
5635184a00830de58920e7e4f3f30464_zps89ea
And a couple more pictures -
fcbdbfb9575928fb2cb0ae279e7dfbad_zps7151
8b797668882ac0e237be6275c2693d65_zps4136
A really nice job done, obviously the pins haven't been pressed into position yet, so won't be sticking out like that when finished. I'm going to get the hinges powder coated soon, speaking of that, I've also taken a lot of things down to be blasted and powder coated, should be picking those up tomorrow so will stick a few pictures up when I've got them.
Edited by big-jay, 21 August 2014 - 09:38 PM.
#237 megamini_jb
megamini_jb
  • 5,491 posts
  • Name: Jamie
Posted 21 August 2014 - 07:15 PM
Such an amazing built!
Loving the splits! How wide did you go? 6"?
Edited by megamini_jb, 21 August 2014 - 07:15 PM.
#238 big-jay
big-jay
  • 518 posts
Posted 21 August 2014 - 07:16 PM
Thanks buddy,
Yes, there 6" wide.
#239 Jared Mk3
Jared Mk3
  • 1,974 posts
Posted 21 August 2014 - 07:24 PM
Been waiting for an update - some real good progress, can't wait to see it in paint.
#240 big-jay
big-jay
  • 518 posts
Posted 21 August 2014 - 08:57 PM
Cheers Jared,
Me either, then just got the mammoth task of putting it all back together again, should be interesting !
