Just to let people know, I've changed the name of this thread in case anyone was wondering.
Reason for this is because when I first started, I wasn't expecting to be doing a complete restoration, but Minis being Minis, it quickly escalated into just that. I think the new name is better suited to what we've been doing, hence the reason for the name change.
Anyway, we've got some more progress done today, I'll start off with what I bought yesterday, and the bits I fitted to my engine.
Some new door hinges, Minispares own, and some new bypass hose clamps. Heard good things about Minspares hinges so I'm hoping they'll be a good fit -
Now onto the engine. Fitted a new uprated water pump, new bypass hose and all bolted into place using a Smiffys Bits stainless fitting kit -
Refitted the thermostat housing. New thermostat, new gaskets and I also bought the ARP stainless bolts to fit it with -
Now onto today's progress, bodywork. Got the scuttle and the scuttle closers fitted, feels like a massive milestone !
But firstly, I had to remove the bonnet hinge brackets as they are really rusty, going to clean them up and re-fit them -
Removed, and the rust cleaned up behind. Will apply some Deox Gel tomorrow -
After that was sorted we moved onto the scuttle, we fitted it to the car and marked out where the closers will be sitting. Removed the scuttle, then drilled the holes in the close out panels and plug welded them into place, plenty of zinc was applied before and after -
Next we drilled the holes in the scuttle and clamped that into place. We made sure to fit the windscreen at this point to be sure I'd have no problems in the future -
Welded into place -
Got a load of grinding to do, but that can wait until tomorrow. Feels really good to have gotten this far, didn't think I'd ever get here when I was finding all those bodge repairs, but I can almost see the light at the end of the tunnel now
Going to make a start on the door skins tomorrow, looking forward to doing those, should be interesting !
Edited by big-jay, 05 July 2014 - 08:20 PM.
