What Cap For The Hycote Spray Paint?
3 replies to this topic
#1 Will16
Will16
    Wants a custom member title
  • 1,090 posts
Posted 29 December 2013 - 12:29 PM
Hi TMF,
I've been given a few cans of this Hycote white primer. However, they have these tops on them. No caps I have fits it. Anyone know what I could use/get a cap for it?
7244b81321b69a90ab3bc4db27d20a27_zps787d
Thanks,
Will
#2 Mini-Mad-Craig
Posted 29 December 2013 - 12:34 PM
If you were given it and it has no cap I probably wouldn't bother with it, primer is the most important part.
Although I'm sure they're made by the same people as Halfords paint, maybe their tips will fit.
#3 HarrysMini
HarrysMini
    I do not have short legs!!!
  • 3,352 posts
Posted 29 December 2013 - 12:57 PM
Maybe I'm being silly, but shouldn't it come with a nozzle/cap/sprayer thingy fitted?
#4 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 29 December 2013 - 04:19 PM
That's not a silly question at all.  The paint would have come with a nozzle.  However, if you don't clear the nozzles when you are through with a job it is common for them to plug.  It is not uncommon to remove a working nozzle from a fresh can of spray paint and use them on a can with a plugged nozzle.  The problem then is that you are "short" nozzles for otherwise good cans of paint.  I admit to being guilty of this and I know I have at least 3 cans of spray paint without nozzles because they have been "loaned" to cans whose nozzle I let plug.
