Cut Wings For 12X6 Wheels?
14 replies to this topic
#1 scotsco
scotsco
  • 76 posts
Posted 29 December 2013 - 10:53 AM
Pretty much as the title says, if I fit 12x6 wheels will I need to cut the wings to allow for the wider wheel?
#2 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,040 posts
Posted 29 December 2013 - 11:11 AM
I'm pretty sure you do, but you may get away with it.
#3 myredmini
myredmini
    My Mummy Says It's OK
  • 3,211 posts
  • Name: Dan
  • Local Club: BOG MOG
Posted 29 December 2013 - 11:35 AM
You will need to trim some material from the front to clear when the wheel turns.
#4 Mini 360
Mini 360
  • 4,933 posts
  • Local Club: Independent
Posted 29 December 2013 - 12:12 PM
Yes.  It has been covered many, many, many times on here before.
#5 scotsco
scotsco
  • 76 posts
Posted 29 December 2013 - 06:38 PM
Ok, thanks a lot guys! And i could only find threads where wings had been cut to allow 13" wheels... :/
#6 Andy!
Andy!
  • 481 posts
  • Local Club: N/A
Posted 29 December 2013 - 09:20 PM
It'll be no different, 13 inch wheels and 12 inch wheels are pretty much the same diameter as the tyres even it out (13 inch have thinner tyres) You mainly need to cut the arches due to the width of the wheel (6 inches in your case)
#7 myredmini
myredmini
  • 3,211 posts
  • Name: Dan
Posted 29 December 2013 - 09:27 PM
All depends on offset too.
#8 scotsco
scotsco
  • 76 posts
Posted 30 December 2013 - 03:17 PM
Ok cheers guys! ;) I presume 10x6 suffers from the same problem then?
#9 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 30 December 2013 - 08:30 PM
yes they are also 6 inches wide
#10 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
  • Local Club: A5 minis
Posted 30 December 2013 - 08:49 PM
I run 12x6 without having cut the wings without problems. I run ao48rs which are lower profile than most 165s so the overall diameter is smaller which may have something to do with it. Clearance is tight (about 3mm) but ok.
#11 scotsco
scotsco
  • 76 posts
Posted 02 January 2014 - 04:04 PM
Thanks for the reply! ;)
#12 danielevison93
danielevison93
  • 222 posts
Posted 07 January 2014 - 04:51 PM
I've got 12x6 and had to trim a bit...
#13 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 07 January 2014 - 05:53 PM
are they fitted to a drum or disk braked mini ?
#14 scotsco
scotsco
  • 76 posts
Posted 10 January 2014 - 08:45 PM
They are fitted to a disk brake mini, currently got 8.4's but got a cooper s set up waiting to be fitted! ;)
#15 Will16
Will16
    Wants a custom member title
  • 1,090 posts
Posted 10 January 2014 - 10:09 PM
I would think you may have to trim the arches a little, as disks sit wider than drums.
