Posted 28 December 2013 - 12:57 PM
I'm looking in to fitting a wideband oxygen sensor to the beast to see what's going on and help with tuning the carb,
There's a tube running from the exhaust which is blanked off and looks like it would fit an o2 sensor
My question is does anyone have one of these? Are they worth the cash, and how accurate is it?
Mark
Posted 28 December 2013 - 01:22 PM
they are good, acurate to about 0.1 AFR, certainly good enough to feed the output into an ECU for closed loop fuel control.
the AEM ones are about 150 quid for the guage and sensor, and I know of a lot of people using those on turbo'd cars,
the sensor screws right into the exhaust flow, so you should see a bolt/plug on the exhaust, where it is will depend what manifold you have,
you can see the sensor on this MPI manifold,
http://www.ebay.co.u...S-/121241943576
if you've got an LCB there may be a fitting (most dont have), if its there it will be down on the Y peice just under the floor.
http://www.moss-euro...ateIndexID=6775
if there isnt one you can get the bosses cheap off ebay and get it welded in, you might even get one with the AEM,
http://www.ebay.co.u...=item3cd49d833b
Posted 28 December 2013 - 01:30 PM
I can vouch for the AEM one, been running it for a few years now. The weld on bosses aren't expensive, but it's even cheaper to buy a nut of the correct thread & weld that on. That's what I did & it cost about 25p !
Phil.
Posted 28 December 2013 - 05:17 PM
Edited by md7708, 28 December 2013 - 05:39 PM.
Mini Technical Sections →
Problems, Questions and Technical →
Can You Help Me Guys With My Hs4Started by Notwabel , Yesterday, 11:32 PM engine |
Clutch Not DisengagingStarted by Sharks , 15 Dec 2024 engine |
Possible Transmission Problem?Started by aguiloco , 07 Dec 2024 engine |
Crud In Combustion Chamber.Started by Rubbershorts , 16 Nov 2024 engine |
Full Rebuild MethodologyStarted by PeteD , 16 Nov 2024 engine, electrical |
