Hi All,
I got some minisport caliper seals for 8.4" disks last year and they have recently failed and leaked fluid. When I took the pistons out (they were tight) I could see that a ring of rubber from the seal had torn off either during use or when I fitted them.
I've come to fit a new set (also from minisport) and the pistons are really tight when I'm putting them back in. Even with red rubber grease I have ripped a ring of rubber from the the seals just fitting them.
How tight should the pistons be when fitting them with new seals? should you be able to press them in by hand? I've been having to use a vise they are so tight!
It seems as though the seal is slightly the wrong size - has anyone else had similar problems? or am I doing something wrong?
Thanks!
