1971 Rally Mini
329 replies to this topic
#271 RODZMINI71
RODZMINI71
  • 260 posts
Posted 20 May 2014 - 07:42 AM
Excellent Picture Rob !!! The reason i went OTL was i lost Dip & Main beam Grrrrrr !! Managed to get the car to Service (Late) Bodged the lights up and then had one of my best driving experiences ever. Alun's sending me copies of the Time cards to see how far of the pace we were.
Excellent Event !! Still smiling ;)
Very Happy with how the Car preformed.
How do i get Copies of the Pictures Rob ? Cost ?
#272 rally1380
rally1380
  • 1,893 posts
Posted 20 May 2014 - 05:57 PM
When's the next event then???
You guys did really well and great to see you at the finish with massive smiles!!!!
Bit of electrical tweeking and you'll be sorted.
#273 jpw1275
jpw1275
  • 2,803 posts
Posted 20 May 2014 - 07:28 PM
Looks fantastic rod and teal blue looks fantastic when it's at minisport..... Luckily for us there isn't many teal blue's around apart from Neil's clubby ( Sonikk )
Cheers james
#274 RODZMINI71
RODZMINI71
  • 260 posts
Posted 21 May 2014 - 08:30 AM
More pictures from the Rally !!
Found  the electrical fault that caused all our problems, i had removed the drivers side cigarette lighter as it was obstructing the cross bar (roll cage) along with the bulb holder which illuminated it.As we crashed down the contacts in the bulb holder arced and fused together. I'm glad i found the problem ;) Just goes to show how the smallest of things can cause a whole heap of trouble.
The car seems to run a little hotter than i would like so the next job is to fit an electric fan and oil cooler. Luckily i have used units on the shelve so just need to plum them in tonight once iv had the hoses made.
#275 GraemeC
GraemeC
  • 7,438 posts
Posted 21 May 2014 - 09:39 PM
Good choice of spots.
Did the number in the back window not do your head in though? Suppose it stops people behind blinding you.
#276 RODZMINI71
RODZMINI71
  • 260 posts
Posted 22 May 2014 - 05:58 AM
I have no reason to look through the back window whilst on a rally, my full attention is given to looking through the front one :)
Did not have any problems with blinding..................nobody got close enough Ha Ha !!
#277 RODZMINI71
RODZMINI71
  • 260 posts
Posted 22 May 2014 - 06:43 AM
37 Days to go until our next event.As long as im quick enough to get my entrance in ! PK Rally, Bala, North Wales it is !!!!!
Regs are not yet available but i'm told there's a Classic Category which should suit the Mini ;)
We will be better prepared this time for certain and i would of had more time behind the wheel.
Very Excited !!!!!!!!!!!!!!!!!!
#278 rally1380
rally1380
  • 1,893 posts
Posted 22 May 2014 - 07:47 PM
Make sure you jack the car up.....the PK is a rough one!!!!!
#279 RODZMINI71
RODZMINI71
  • 260 posts
Posted 22 May 2014 - 08:45 PM
On it ! Just received some tips from Cooperman. Iv been told it runs through a Quarry so ill be ordering a sheet of 2mm Aluminium Monday !!
Will be taking a lot of care checking my Electrics before the event ;)
#280 rally1380
rally1380
  • 1,893 posts
Posted 22 May 2014 - 09:14 PM
2mm Alley.....what for?
#281 RODZMINI71
RODZMINI71
  • 260 posts
Posted 23 May 2014 - 06:18 AM
To protect under the car, ill be using thicker stuff to plate either side of Rear Silencer and under Rear Brake Pipes.
#282 rally1380
rally1380
  • 1,893 posts
Posted 23 May 2014 - 07:57 AM
Wouldn't have thought 2mm alloy would be up to much and if you've put the lines and battery cable inside you're not really protecting much other than the paint....which on your super neat car is fair enough.
Definately try and skid the rear subframe and battery box areas. I might change my rear brake pipes to aero braided stuff with a banjo fitting and run them up and over the hub rather than how the standard ones stick out in a vulnerable way....might be worth considering?
Ride height is your friend on the PK in a mini i reckon.....heard a few comments about last years event.
If you want a pair of free front door glass to replace yours let me know....got a couple somewhere and i'll be over your way soon.
#283 minisi35
minisi35
  • 723 posts
  • Local Club: british mini club shropshire
Posted 23 May 2014 - 08:47 AM
Ive done the PK and it can be very rough. Fantastic event though one of my personal favourites . Shame im working that weekend else I would eneter to give you some competition :proud:
#284 RODZMINI71
RODZMINI71
  • 260 posts
Posted 25 June 2014 - 06:45 PM
Almost finished prepping the car for the PK
Why i leave things to last minute i'll never know ;}
Hope to lend a mates 4 post lift to fit some much needed under armour !
Now that i have clocked up some miles since my last Rally i hope i have now found and dealt with the post build glitches. I now know by experience no matter how much power your car has or how well it handles without lights your going no where fast !
If there is anybody reading this and building a car for a sillier purpose DO AWAY WITH ORIGINAL LIGHTING LOOM/CIRCUIT AND  CONSTRUCT YOUR OWN !! Ensure both Main and Dip beam have there own independent fused supply N/S and O/S.
Wish me luck ;)
#285 Rob Jones
Rob Jones
  • 40 posts
  • Local Club: North Wales Car Club
Posted 30 June 2014 - 09:56 AM
Well ... he finished!!
Photo from the first test in the quarry
