Posted 12 December 2013 - 09:16 AM
As above, you can run without one with no issues. I've had to resort to doing just that, thanks to quality problems with replacement heater taps of late.
Obviously if you cant close off the heater circuit, then there will be a constant year round flow of hot coolant through the matrix, meaning that the heater will permanently throw out some heat. On very hot summer days, this can make the classic mini tin box oven even more unbearable, but on the upside the matrix also acts as a second rad so it will help with cooling on particularly hot days too. The other advantage of having a year round flow of coolant around the heater circuit, is that you don't get the inevitable build up of sludge and debris collecting in the matrix over the summer months, that causes blockages, corrosion and all the associated leaks and classic mini heater faults at the beginning of each winter.
