How Do You Clean Your Chrome?
22 replies to this topic
#16 Carlos W
Carlos W
  • 10,114 posts
Posted 10 December 2013 - 10:30 PM
I like meguirs on chrome and mirror polished alloy, it's not as abrasive as autosol
belgom chrome, i use it on ally stuff when i finish polishing.
I PM'd you a while ago about a carb rebuild mate, can you check your inbox?
#17 1984mini25
1984mini25
  • 8,784 posts
Posted 10 December 2013 - 11:07 PM
I've always used autoglym super resin polish and then silvo silver polish, buffed up to a deep shine.
#18 Mini 360
Mini 360
  • 4,933 posts
  • Local Club: Independent
Posted 10 December 2013 - 11:43 PM
Mothers Metal Polish.  Smooth stuff and works in no time with zero pressure.  £10 a pot but lasts forever.  Wouldn't be without it in my detailing bag :)
Then just a decent wax/sealant onto it to protect the finish.  Should only need to clean it with polish a couple times a year.
Edited by Mini 360, 10 December 2013 - 11:45 PM.
#19 lewBlew
lewBlew
    Previously known as theboybradley.
  • 1,238 posts
Posted 11 December 2013 - 01:44 PM
I've never had anything but good results with Autosol.
However if they are getting a bit rusty on the surface I posted on this a while back: http://www.theminifo...il#entry2533750
thats a good idea :) ill try that this weekend will cheap 34p cola work or does it have to be the proper stuff? Also will it work on the grill?
Cheap cola is fine, just don't use diet!
#20 CCX
CCX
  • 517 posts
Posted 11 December 2013 - 07:15 PM
I took my grille off to polish it before, and just rinsed it down with the hose first (to remove any dirt, as you don't want to be polishing the dirt and grit into the chrome, it will scratch it) and then used some Auto Glym super resin polish (the same stuff you use on paintwork). It looked like new afterwards! Just make sure the surface is free from any dirt before you apply the elbow grease, as you'll end up with scratches if not.
#21 Ripple
Ripple
  • 116 posts
Posted 11 December 2013 - 07:20 PM
call me stupid but ive always used toothpaste on chrome... works a treat and doesnt wear the chrome away
(also works a treat on cleaning up new car plastic light enclosures when they start to look tatty, brough my focus and vectra lights up beautifully)
Edited by Ripple, 11 December 2013 - 07:21 PM.
#22 jaydee
jaydee
  • 8,565 posts
Posted 11 December 2013 - 09:45 PM
Toothpaste is also good for headlamps plus your car will smell nice and fresh :P
I use 3m fine paste if the chrome is faded, otherwise some very mild generic polish diluited with tap water will do the trick.
#23 welshdan
welshdan
  • 643 posts
  • Local Club: ?
Posted 18 December 2013 - 05:48 PM
autosol does the trick for me
