How Do You Clean Your Chrome?
22 replies to this topic
#1 Kieranlee999
Kieranlee999
  • 1,401 posts
Posted 10 December 2013 - 01:44 PM
Well as some of you know im new to minis altogether :P and i was wondering what methods people use to clean you grille and bumpers? ive just been using car soap and washing it with the rest of the car bit ive noticed all the water marks left on D: so any other method of cleaning it?
#2 lawrie124
lawrie124
  • 1,710 posts
Posted 10 December 2013 - 01:49 PM
some mild chrome polish will do the trick, but NOT metal polish (autosol etc).
there is some way of removing pitting using coke and silver foil, but I just ended up with a sticky mess on my bumpers!
#3 creakyjaws5533
creakyjaws5533
    My jaw needs oiling. Where's the WD40??
  • 1,195 posts
Edited by creakyjaws5533, 10 December 2013 - 01:49 PM.
#4 silve1999
silve1999
  • 1,146 posts
  • Local Club: MiniFreakz, Brighton Mini Club
Posted 10 December 2013 - 01:59 PM
i use silvo and elbow grease which does a good job on surface rust....... then autoglym metal wax dunno how recommended it is but seems to work for me.
#5 lewBlew
lewBlew
    Previously known as theboybradley.
  • 1,238 posts
Posted 10 December 2013 - 02:10 PM
I've never had anything but good results with Autosol.
However if they are getting a bit rusty on the surface I posted on this a while back: http://www.theminifo...il#entry2533750
#6 Gerbil367
Gerbil367
  • 646 posts
  • Local Club: GMOC
Posted 10 December 2013 - 02:11 PM
I tend to just rub the chrome with a soft cloth that has some WD40 sprayed onto it.  Works for me (so far).
#7 Kieranlee999
Kieranlee999
  • 1,401 posts
Posted 10 December 2013 - 02:14 PM
thats a good idea :) ill try that this weekend will cheap 34p cola work or does it have to be the proper stuff? Also will it work on the grill?
Edited by Kieranlee999, 10 December 2013 - 02:15 PM.
#8 Hrimfaxi
Hrimfaxi
  • 455 posts
  • Local Club: LSMOC
Posted 10 December 2013 - 02:15 PM
I use Kleers "The Metal Polish" - works a treat.
#9 AVV IT
AVV IT
    I am a shed dragger.
  • 6,122 posts
  • Name: Dave
Posted 10 December 2013 - 02:41 PM
You'll certainly get fantastically shiny results with Autosol, at least initially anyway!!  :(
The problem is that Autosol (the stuff in a tube) and most other metal polishes, is that they are just too abrasive for use on chrome. Chrome plating is really quite thin/delicate and if you us Autosol on it regularly, then you'll soon rub through to the metal beneath. I know because I've done it, I ruined my first pair of chrome spots through hours of enthusiastic polishing with Autosol!!  >_<
So ideally, you need a less abrasive polish specifically for chrome, Autosol actually make one called "Autosol Liquid Chrome Cleaner", but there are many others available. http://www.amazon.co...s=chrome polish
You actually can get pretty good results just using normal toothpaste!! It might sound a bit daft, but toothpaste is ideal because it's abrasive enough to clean, but without being so abrasive that it wears away the enamel on your teeth, much like what you're trying to avoid with the chrome plating on your metal. It'll also make your mini smell minty fresh and dentists would probably recommend it too, particularly if you've tried cleaning your chrome with coca cola first!!  :lol:
#10 Chance
Chance
  • 1,457 posts
Posted 10 December 2013 - 02:48 PM
Is brasso abrasive?
I know I used to use it on my dads old pajero rear bumper
Works great but don't know if it will have the same issue as autosol?
#11 Mini ManannĂ¡n
Mini ManannĂ¡n
  • 2,856 posts
  • Local Club: man Estate
Posted 10 December 2013 - 03:00 PM
Autosol then a coat or three of the best carnuba  wax.
#12 surfblue
surfblue
  • 1,827 posts
Posted 10 December 2013 - 03:10 PM
Is brasso abrasive?
It certainly is!
A polish up with something like autosol initially to take any tarnishing / oxidation off then if kept clean just use your regular car polish and do them when polishing rest of car, I do mine every time I polish it, but to be fair it lives indoors most of the year and never sees bad weather!
#13 lawrie124
lawrie124
  • 1,710 posts
Posted 10 December 2013 - 03:41 PM
AGREED
#14 Craig89
Craig89
  • 600 posts
Posted 10 December 2013 - 04:34 PM
I use aluminum foil and water to rub away any pitting then polish with chrome polish
#15 ANON
ANON
  • 2,682 posts
  • Local Club: pony
Posted 10 December 2013 - 10:21 PM
belgom chrome, i use it on ally stuff when i finish polishing.
