Setting Primary Gear End Float
10 replies to this topic
#1 minilee94
minilee94
  • 3,523 posts
Posted 08 December 2013 - 05:39 PM
Today I fitted the primary gear etc and then checked the end float with a feeler gauge and I can get about 7thou feeler gauge in there 8 at a push am I checking it the correct way can't see very well but feeler gauge is between the thrust washer and gear
I am going to replace the c lip and I need a new thrust washer for a fatter one
#2 minimadles
minimadles
  • 136 posts
  • Local Club: not as yet
Posted 08 December 2013 - 05:42 PM
Measure it at the other end or better still stick a DTi on it
#3 minilee94
minilee94
  • 3,523 posts
Posted 08 December 2013 - 06:08 PM
Okay I did do it there the 1st place I see on te Internet about doing it the way the pic is showed I didn't think it mattered but il measure from the other end from now on
#4 minimadles
minimadles
  • 136 posts
Posted 08 December 2013 - 06:22 PM
It's just easier to to check at the front
#5 The Principal
The Principal
  • 763 posts
Posted 08 December 2013 - 06:25 PM
try this - http://www.minispare...55-d804159216f3
#6 Gr4h4m
Gr4h4m
  • 1,802 posts
  • Local Club: Club less.....
Posted 08 December 2013 - 07:26 PM
If using feeler gauges Use two at 180deg to each other so that your not just pushing everything to one side. I measured mine at the other end.
Edited by Gr4h4m, 08 December 2013 - 09:11 PM.
#7 minilee94
minilee94
  • 3,523 posts
Posted 08 December 2013 - 08:54 PM
Okay what do you mean at 90degrees cheers
#8 Gr4h4m
Gr4h4m
  • 1,802 posts
Posted 08 December 2013 - 09:10 PM
Edit sorry I meant at 180deg ie, opposite sides of the ring so you measure the gap even...
#9 minilee94
minilee94
  • 3,523 posts
Posted 08 December 2013 - 10:22 PM
Or right yeah I though so so feeler gauge at top and one at bottom
#10 Gr4h4m
Gr4h4m
  • 1,802 posts
Posted 08 December 2013 - 11:20 PM
or side to side I measured mine at the front, rather than behind the gear.
#11 Fast Ivan
Fast Ivan
  • 2,909 posts
Posted 08 December 2013 - 11:33 PM
everything you need here
