Difference Between 3 Types Of Mini Brake Pedal.....
7 replies to this topic
#1 mab01uk
mab01uk
  • 12,522 posts
Posted 07 December 2013 - 10:42 AM
Below shows the difference between 3 types of Mini brake pedal.
They all have the pivot and clevis pin hole fixed to show the differences.
The first pedal is a standard drum brake pedal off a Mk1, the second pedal is a genuine S disc pedal and the third is a late 80's type pedal with the foot pad cut down to earlier size.
The Cooper S disc pedal has the foot pad approx 15mm higher than the drum brake pedal and the later pedal (Mk4 onwards) is another 20mm higher than the S.
More info and discussions on the effect this has on braking feel, etc, when swapping brakes here on Mk1 forum:
http://mk1-forum.net....php?f=3&t=8121
#2 Ethel
  • 26,061 posts
Posted 07 December 2013 - 12:42 PM
Thanks, that should kill off any potential arguments in the footure!
What about the distance between the holes, is that the same on all three? I was led to believe the later pedal's are closer. The piccy also makes me wonder if later clutch pedals also differ, the offset looks huge if they are the same as original drummer.
#3 robminibcy
robminibcy
  • 1,516 posts
Posted 07 December 2013 - 04:32 PM
What about later drum braked minis(late 70s early 80s) would their pedals be the same as the mk1? Would factory cars with a servo use the third pedal along in your pic?
#4 Ethel
  • 26,061 posts
Posted 07 December 2013 - 05:18 PM
There's only one dual circuit pedal, unless the horizontal servo one also has dimension changes. They're all done for reserve pedal travel, so no reason to alter for the horizontal master with the largest bore of the lot.
#5 mab01uk
mab01uk
  • 12,522 posts
Posted 08 December 2013 - 11:20 AM
Later drum braked Mini's would use the Mk4 pedal box with the larger footpads which became standard across the range.......same as the third pedal in pic. Not sure about the drum braked Mk3's were they upgraded to Mk1 S pedals.....?
The later horizontal/cantilever type servo pedal is also the same as Mk4 I believe but just has a different pushrod arrangement fitted, as Ethel says all done for reserve pedal travel and beefing up the pedal metal thickness. Investigation started because some on the Mk1 forum had found poor brakes when fitting S discs to drum braked Mk1's without also swapping over to disc type S brake pedal.
Edited by mab01uk, 08 December 2013 - 11:23 AM.
#6 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 09 December 2013 - 11:41 PM
I've moved this into the FAQs so it can be found again for those looking
#7 Ethel
  • 26,061 posts
Posted 10 December 2013 - 01:01 AM
I have a late Mk3 pedal, from after the demise of the "S" it's the standard type. I also used it with S discs (single circuit) with no issues.
#8 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,079 posts
  • Name: Neil
Posted 20 December 2013 - 10:37 PM
Its actually good to see pictures to back up all of the various comments made about the different pedals and their respective angles etc.
Just to add i have a MK3 Clubman that had drums and now converted to 7.5" discs along with a Cooper S master cylinder. Small brake pedal and to be honest it works well and i'm more than happy with it.
