Tried digging around, and I couldn't really come up with anything on these forums or else where. I vaguely remember seeing some Mini's at the track with raised subframes to lower the height of the car. I assume I would have similar obstacles as a Sprint car with hood clearance. Possibly raise exhaust/shifter tunnel, remake lower/front mounts, shave off the top mounts. I wanted to try something different and gain ground clearance of gearbox, at ride height it would still have "factory geometry" while getting it lower, really low. Possibly laying the front on the ground. This will be the forth car I have fabricated air suspension from scratch, and I have some ideas kicking around. Anyone have thoughts on this or pics of this mod I am describing?
Probably seems daft to most, but the proportions are not where I want them to be on the Estate. I want the arches sat higher on the body, and the wheels tucked up in there. Rear I was going to tub, and then turret to fit the air sleeves. Almost do something along the lines of a rear beam setup.
Here is my 61 Morris Minor early in the process...
