Oil Pressure Light Coming On At High Rpm
7 replies to this topic
#1 miniboy94
miniboy94
  • 64 posts
Posted 02 December 2013 - 06:09 PM
right iv been looking on the tinterweb and carnt find a bloody thing, i fitted a oil pressure gauge about 1 and half mouths ago now to my car as when i was iderling my oil light came on so wanted to see what was up with it but ever since i fitted the gauge the oil light hasn't come on only when you start it in the morning eg turn ignition on. but now developed a new problem was driving it around the other day quite hard and at about 4000-5000 ish rpm my oil light started to illuminate on the dash i changed gear and it went out then didn't see anything again or anything of it. but now the past day or two it has been doing it more frequent at about the same rpm ? my gauge is reading about 50-60 iderling but will drop after leaving it a while to around 25ish, and when at full chat or hard on throttle which ever you say it ready about 70ish ?( its a smith gauge so not sure if it is psi or not ) but basecly my question is if my oil pressure light is coming on at high rpm could it be a warm oil pump ? or something else much worse i did a service about 1 Mouthe before i fitted the gauge to my car , oil , filter , plugs the lot
any ideas would be great thanks ben
#2 Cooperman
  • 23,278 posts
Posted 02 December 2013 - 06:17 PM
Forget the light and read the gauge.
It should have around 15 to 20 psi at 800 rpm when hot and around 50 psi at 3000 rpm when hot, 60 psi at 5000 rpm and over when hot.
#3 miniboy94
miniboy94
  • 64 posts
Posted 02 December 2013 - 06:48 PM
ok il keep a close eye on the gauge next time i go driving around like and see what it reads then get back to you :)
thanks cooperman
#4 jaydee
jaydee
  • 8,565 posts
Posted 02 December 2013 - 07:28 PM
Looks like the sender is earthing. Just replace it.
If the gauge is of the mech type, then you have to trust the gauge. But fix the warning light aswell ;)
#5 miniboy94
miniboy94
  • 64 posts
Posted 03 December 2013 - 07:44 AM
i put a new oil presure light in not long ago well from my 1275 engine what i had in my last mini and i never had a proplem with that so and yeah its a mech gauge :) with the long oil pipe running to and from it like
thanks jaydee :)
#6 miniboy94
miniboy94
  • 64 posts
Posted 04 December 2013 - 11:08 PM
right tryed to get my oil light to come on again and now i carnt get it to iv ran it full half a tankso its nice and warm and still carnt ? could it be a fault sensor or just an intomintent fault ?
thanks ben
#7 lrostoke
lrostoke
  • 6,923 posts
Posted 05 December 2013 - 08:25 AM
easy enough test the sensor...touch the wire onto the engine block. If the light comes on ...dodgy sensor
#8 miniboy94
miniboy94
  • 64 posts
Posted 05 December 2013 - 11:27 PM
right ok thats easy test iv ever done thanks ironstoke :D il try that tomorrow morning :D
