Nice progress on that motor
#106
Posted 23 September 2016 - 04:21 PM
#107
Posted 23 September 2016 - 06:52 PM
Thank you Jared
Here´s a picture of todays progress
#108
Posted 25 September 2016 - 08:25 PM
A little more progress on the engine today, its pretty much ready to be put in, just need to finish a little bit more in the engine bay.
Cleaned up and installed the tightening bracket for alternator, radiator on but need a few screws.
Wrapped the exhaust in powerwrap to lower the temperature in the engine bay. A shame to cover op such a nice Fletcher lcb manifold.
Had the ultrasonic out and cleaned some bike carbs for a Kawasaki GPZ1000, quite a difference.
Edited by Cavazzi, 25 September 2016 - 08:26 PM.
#109
Posted 02 October 2016 - 06:03 PM
Been a busy week involving lots of beers and cars.
Bought a new daily driver, a Seat Altea 2,0 TDI, and with that sorted i got back to the mini. Recieved the interior from Newton, and must say im very disappointed by the quality and the front carpet was far from a proper fitment. Havent checked the door cards yet, but im hoping they fit ok.
Also bought a set of 38mm carburettors for a cbr900 fireblade to which im in the process of making a manifold for. It will be split into 2 and spaced apart to get the best flow.
#110
Posted 07 October 2016 - 07:06 PM
What a day!
The engine is in the car!
Shoe horned it in, and quite annoying to fit the bolts but its done, and didnt scratchs anything. Me trying to fit the last bolt.
A template for the inlet manifold
Manifolds in the car, had to remove the powerwrap as it wouldnt fit in the close space.
Checking if it would fit, which they without doubt would Gonna sound nice. Distance from head to shaft on carbs are close so same distance as on twin HS2's.
More to come over the weekend
#111
Posted 07 October 2016 - 09:24 PM
Nice one Christian. I'm looking forward to seeing how it goes on those carbs.
#112
Posted 21 October 2016 - 06:31 PM
This is probably gonna be the last update for a while, as i soon have to go on work again for another 10 weeks.
I have spent the last couple of weeks finishing of the engine install, driveshafts etc.
Also recieved the new wiring harness which of course needs to be modified to suit my car and needs. more or less finished the engine room but waiting for a fuse and relay box to show up. Fuse and relays will be placed inside the car to give a cleaner look in the engine room.
Sourced a new wipermotor and finally managed to find some brackets for the brake pipes, they came from a Ford Capri and fits perfectly.
Got the wheels back from the wheel shop where they fitted some rubber to them, went with Yokohama A032R semi racing slick and they look awesome on the car, i really like the subtle racing look.
Got the carburettors separated and extended the tubing between them, only need to weld on some studs for fuel pipe and breather, and a small stud for vacuum for distributor.
Didnt like the top steady bar, and made a "clean" looking one from stainless steel.
Today i recieved a oil catch tank and made up a bracket to install it in the right side of the engine room. If anyone noticed, in one of my previous post´s, you can see a small connection for a hose on the right tappet cover. gonna make another one on the tappet cover too, but need to improve my tig welding skills a little before attacking that task.
Thats all for this time
Christian Cavazzi
#113
Posted 21 February 2017 - 08:36 PM
Well, its been a while since last update. Was at work for 10 weeks and then on a skiing trip to Italy, but now im back working in the Van
Wanted to make an update before going to work but photobucket wouldnt work. before i went of i finished the wiring loom and a few other bits and bobs i dont remember.
Letting the pictures do the talking as usual:
Bought some original Ermax side repeaters. The law in Denmark dictates its possible to see the indicator from the side too, so they are necessary.
Installed on the B-pillar, looking very neat.
Installed a new fusebox utilizing flat fuses, and relays for lights. The car now holds 4 relays and 16 fuses
Relays are for: flasher, emergency flasher, light, and highbeam
Also got some new seats, from a german built Mini convertible.
Also got to work on the dash, picture is after the finer have been removed, but new is alreader glued on just need to lacquer it.
How it looked when i left for work.
When i came home we installed the electric fuel pump and filter. Also the exhaust is finished but i dont have any pics at the moment.
The car is actually standing on its wheels now, although on some blocks to have a better working height.
Just this sunday we installed the new laminated windscreen. Went in without problems with enough grease.
A new update will follow in a few days.
-Christian Cavazzi
#114
Posted 17 April 2017 - 01:02 PM
Hi Christian
The project is really looking great. Nice to see the attention to details :)
I like the idea of putting the fuel pump near the tank. It looks nice. What fuel pump did you end up using?
I'm from DK too, any dealers of that pump in the country?
-Rasmus
#115
Posted 26 April 2017 - 12:42 PM
This van looks awesome, so clean and fresh! i love that idea for the side repeaters on the at b pillar! They are nice touch.
#116
Posted 07 May 2017 - 04:53 PM
Hi Christian
-Rasmus
Thank you very much. Where do you come from in Denmark? maybe we should meet up someday?
regarding the fuel pump; the pump i bought was a noname of ebay for 150dkr. Its very noisy and will be changed to a secondhand pump of a better brand, possible honda og yamaha originals. The setup at the rear is no problem to make although i prepared the subframe with rivnuts before powdercoating but it can also be done after.
Im currently away for work, but before i left the car was on its wheels and running down the street, while i tried to tune in the new carburettors, i think i almost got them tuned right. Doors are finished and the dashboard extended with a rev counter, water temp gauge and oil pressure gauge, just need to find a transmitter for the oil pressure.
I will try to upload some pictures later if we get good enough internet connection.
#117
Posted 08 May 2017 - 09:12 AM
Is your pump solidly mounted? if so fitting it onto anti vibration mounts will quiten it down a lot
#118
Posted 11 May 2017 - 09:00 PM
Partially, It has rubber bands between, but even when holding it in your hand its very noisy. It was mostly a test setup to see if it would work with the cbr900rr carburettors.
Also tagged with one or more of these keywords: van
Projects →
Mini Variants →
Australian 1970 Morris Mini K VanStarted by braad , 16 Mar 2023 van |
Projects →
Mini Variants →
1977 Portuguese Ima Van With LiftgateStarted by one60 , 22 Sep 2022 van |
Projects →
Mini Variants →
Mini Van Fuel Tank FittingStarted by Dylpants80 , 29 Jan 2022 van |
Projects →
Mini Variants →
Mini Van RestorationStarted by DJStrange , 21 Feb 2019 van |
Projects →
Mini Variants →
1974 Mini Van - Back To Basics BuildStarted by Vudu , 13 Jan 2019 van |
6 user(s) are reading this topic
0 members, 6 guests, 0 anonymous users
