1964 Mk1 Morris 850
853 replies to this topic
#121 timmy850
timmy850
  • 3,291 posts
  • Local Club: MITG
Posted 18 February 2015 - 11:23 AM
Good to see you getting some progress here  =]
I haven't been very productive, the cars been broken a month now! Hopefully it'll be sorted soon..
I got a new mirror today. It's a Raydot replica, which were also called Downton mirrors.
The door looked like this with the old mirror removed. I'll get another rubber grommet to block up the second hole
And installed
It bolts into the front window catch
I've also got all the bits to rebuild the diff with the HS joints. One of the planet gears is a bit loose on the diff pin so I'll need to chase that up. I made a little progress today and removed the uni joint from one of the HS joints, I'll need to get some proper circlip pliers to get the other one apart
#122 Jared Mk3
Jared Mk3
  • 1,974 posts
  • Local Club: MOCKZN
Posted 18 February 2015 - 03:36 PM
I do like that mirror.
#123 timmy850
timmy850
  • 3,291 posts
  • Local Club: MITG
Posted 21 February 2015 - 06:30 AM
Thanks! Makes me wish there wasn't holes in the door already though..
I've got the universal joints stripped down and ready for new inner bearings. They got a coat of paint too!
The diff has been pulled apart ready to be rebuilt, and I've also got some red engine paint to redo the engine and gearbox. I'm not sure whether to repaint the rocker cover too (it was originally blue) with some wrinkle paint or leave it as bare alloy.
#124 Vinay-RS
Vinay-RS
  • 2,112 posts
Posted 21 February 2015 - 01:33 PM
Those look like new!
#125 timmy850
timmy850
  • 3,291 posts
  • Local Club: MITG
Posted 23 February 2015 - 10:14 AM
It's surprising what a coat of paint does sometimes! They're all done now with new universal joints and rubber boots
#126 Jared Mk3
Jared Mk3
  • 1,974 posts
Posted 23 February 2015 - 11:55 AM
I wouldn't mind a set of these. Looking good there!
#127 timmy850
timmy850
  • 3,291 posts
  • Local Club: MITG
Posted 24 February 2015 - 09:29 AM
I have got another set around that needs a rebuild... They'll probably be going on my 1100 engine. It's handy that they share the same driveshaft splines so that I don't have to swap them either (the pot joints have different driveshafts). This is how they looked when I got them
I've got a replacement planet gear on the way which should turn up tomorrow..
#128 Jared Mk3
Jared Mk3
  • 1,974 posts
Posted 24 February 2015 - 05:41 PM
Great job you've done. I may have to persuade you at some stage ;D
#129 StewartB
StewartB
  • 93 posts
Posted 24 February 2015 - 08:16 PM
Love this car, i really do and with that engine out give a good excuse to tidy and paint  :lol:  lovely motor!
#130 timmy850
timmy850
  • 3,291 posts
  • Local Club: MITG
Posted 24 February 2015 - 10:12 PM
Cheers, I'll be very happy once it's all back together again. I haven't decided for sure what to do with the spare set of HS couplings, I'll let you know though.
Thanks! It's another one of those jobs I wish I didn't have to do, but I may as well clean up the engine bay while I'm at it.
Here are all the parts from the rubber cross joints except the castellated nut and split pin. Preferably your u-bolts will be nice and straight!
And these are all the bits you'll need to swap to Hardy Spicer joints. They have larger diameter diff side covers than the rubber cross and pot joints. It's also a good idea to swap the planet gears, diff pin and diff bearings while you have it all apart.
I'll see if I can weigh both sets as a unit to compare the rotating mass between them..
Edited by timmy850, 25 February 2015 - 03:36 AM.
#131 Jared Mk3
Jared Mk3
  • 1,974 posts
Posted 25 February 2015 - 05:54 AM
I'd appreciate it  =]
#132 timmy850
timmy850
  • 3,291 posts
  • Local Club: MITG
Posted 27 February 2015 - 11:34 AM
The diff pin and pinion washers were worn in the current diff...
And so was the diff cage.
I stripped down the 3 other diffs I had and this one looked in good nick. I've found a nice pair of output shafts to go along with this. Hopefully I can build it all up on the weekend.
One of the other diffs was even more worn the my current one!
#133 timmy850
timmy850
  • 3,291 posts
  • Local Club: MITG
Posted 10 March 2015 - 06:59 AM
The new diff gears and pin have been installed into the diff cage.
The crown wheel and bearings were done next. I've measured the diff tolerance and ordered the shims to get the diff installed this week hopefully.
I also cleaned up the diff housing and regreased the shift mechanism.
The remote extension was pulled apart, cleaned up and regreased too. I had to use a replacement extension as the old one had stripped the thread for the gearshift locating pin, and there shift rod had a bit of wear in it too.
While it was apart I also cleaned and regreased the gearshifter. It has a nice smooth action now when moving through the gears.
The outside of the engine is getting a quick spruce up while it is out. A lot of the paint had already peeled off the engine block. It is getting a couple of coats of red paint so hopefully it’ll look a bit tidier under the bonnet...
#134 timmy850
timmy850
  • 3,291 posts
  • Local Club: MITG
Posted 18 March 2015 - 03:23 AM
The engine has come up nice and shiny with a few coats of red. The camera phone doesn't capture the colour like it looks in person. I was a bit lazy with the masking so there is a little overspray to clean up   :lol:
It took me a while to get the diff shims all sorted (mainly because it took me an hour or so to finally find a set of feeler gauges) but I got there in the end.
The diff side covers and shift linkage were installed and it all moves smoothly. I've still got to get some nuts for the output flanges to bolt the Hardy Spicer joints in. The output flanges also need to be bolted to the output shafts.
I got sick of moving parts around the place so I've temporarily put the manifolds and rocker cover on the engine. This rocker cover currently doesn't have a breather on it so I'm not sure if I will need to put one in. It still has the breather from the tappet cover to the air filter.
#135 Jared Mk3
Jared Mk3
  • 1,974 posts
Posted 18 March 2015 - 05:31 AM
Looking good mate  =]
