Edit: double post
Edited by timmy850, 14 December 2023 - 04:29 AM.
Posted 14 December 2023 - 04:27 AM
Edit: double post
Posted 31 December 2023 - 09:37 AM
Last update for the year:
My spare steering rack has gone out for a refurb and I'll hopefully get that back in a few weeks. I'm trying to figure out the best way to swap this, either drop the subframe a little or I may even remove the engine first. There's probably a few parts to replace while it's out too, so I'll need to think of what to order
Another random purchase from facebook
Some NOS Brown and Geeson wheel trims. They really transform the standard steel wheels!
I'm also planning ahead for using the HIF44 carb. A gasket kit has been ordered, along with some extra needles and dashpot spring. The dilemma I had was whether to use the Metro manifold or get a new minispares type. I had read that some minis have clearance issues with the carb and bulkhead, but this particular combination worked for me. The only problem was the difference in flange thickness between it and the exhaust. You can see the gap in this picture
Drmini was able to make up some stepped manifold washers for me. They are approx 4mm to adapt the Metro manifold to the modern Maniflow exhuast.
Lastly I had a free afternoon during the holidays and had a decent chance for a drive and a few carb tweaks. It's now running nice and smooth and I'm starting to get my confidence back again after the few mechanical issues. Once the steering rack is replaced I'm hoping it'll be even better
Plans for 2024:
Replace the steering rack
Install the bucket seats (the stock seats are getting tired). Install the old static seatbelts
Rebuild and install the HIF44 and get a better idea on tuning SU carbs. The twins have been OK but tricky to know if they are synched properly
Diagnose and rebuild the Dellorto
Clean and assemble the H4 carbs
Prepare the Maxrob for installation (drill and tap 2 x holes for the trim ring)
Rebush rear radius arms. This will mean basically all the mechanical parts have been rebuilt or replaced since I've taken on the mini
The mini will also be 60 years old in 2024, so hopefully I can do something special for that!
Posted 31 January 2024 - 01:08 AM
Posted 05 February 2024 - 03:52 AM
Posted 05 February 2024 - 08:38 AM
that's a good return from a weekends work. remarkable how little corrosion there is to be seen
Posted 06 February 2024 - 07:55 AM
Thanks! I feel like I've got most of this at the right time.
I have the day off tomorrow and I'm hoping to at a minimum get the new rack in and the subframe back in the shell. The remaining little things can be done evenings when I've got a few hours
Posted 08 February 2024 - 10:12 AM
I had the day off on Wednesday and got a few things done. The bulkhead near the master cylinders looks much better now
As do the corners
The subframe had some crusty spots on the top of each side
Both sides have now been cleaned and painted, along with the spacers that go between the subframe and body.
Next up was to reassemble the rack. This ended up taking nearly 6 hours, with cleaning, painting, dry assemble, go to the shop for gasket sealant, final assemble, go to the shop for boot clamps and a measuring/pouring jug, finding the CV band tightening tool. Filling it up with oil took ages as the oil is so thick!
Out of curiosity I quickly took the covers off the old rack and it wasn't great. There was no oil left at all, just some solidified grease around the pinion
It took nearly an hour to then get the rack bolted to the body. The U-bolts put up a real fight, they started off being opened too wide, so I squeezed them in a bit so they lined up fine with the holes in the body. But once they were wrapped over the new rack they would splay apart again. I measured the new rack was slightly bigger in diameter, which caused the bolts to not line up. I had a look through my spare parts and found another MOWOG branded U bolt and it fit perfectly. I then chose the best of the original ones and finally got it all bolted together
At this point I ran out of time and needed to check up on the U bolts before I put in the subframe. After some investigation it seems I will need to find some shorter nylock nuts, as it seems the early type rack has slightly longer nuts which don't engage properly with a later rack and spacers
This afternoon I managed to find 4 brand new nylock nuts that I'd bought for the HIF manifold
Now there is enough thread through the end
No leaks from the rack so far which is awesome
Posted 08 February 2024 - 10:48 AM
Nice work, should give you peace of mind that the tin worm isn't chomping away under things!
Posted 09 February 2024 - 10:51 AM
Yep, it's always nice to know at least this part is in good condition and will be sorted for a while.
Two more photos for this evening's effort:
Posted 09 February 2024 - 06:57 PM
This is seriously impressive work! Well done, Tim!
Posted 10 February 2024 - 05:12 AM
Thanks Vinay!
Now the hardest job will be deciding how much to clean and paint everything when I reassemble it!
Posted 10 February 2024 - 10:41 PM
Thanks Vinay!
Now's the time to do it while it's off!
Posted 14 February 2024 - 02:15 AM
Thanks Vinay!
I do need to strike the balance between making it all nice and not taking too long. I need it all back together in about a month before the annual inspection
Next chance I get in the garage I'll be removing the rear arms so I can take them away for a refurb
Posted 29 February 2024 - 10:34 PM
I haven't had much time recently to get a lot of the reassembly done, so far I've got the alternator, starter and ignition system in. The next major item is to clean up the bulkhead plates (heater, master cylinder and heater hose blanking) and give them a coat of paint.
I'm also spending a bit longer to check over everything and redo some of the previous fixes. The wiring will be simplified, the heater will be removed for the moment and an overall tidy up of the engine bay. I've also found a few things that were loose like speedo pod bolts, speedo 90 degree adapter and the distributor locking wire so these will all be sorted now too
Also another opportunity to mock up carbs
I am liking the simple look of the HIF44
Posted 29 February 2024 - 10:37 PM
