1964 Mk1 Morris 850
858 replies to this topic
#766 timmy850
timmy850
  • 3,607 posts
  • Local Club: MITG
Posted 28 July 2022 - 10:30 AM
I picked up the exhaust manifold from the exhaust shop yesterday after they welded the O2 sensor bung in. They now need a quick scrub and a new coat of paint - they will need to be installed first before the head
#767 timmy850
timmy850
  • 3,607 posts
  • Local Club: MITG
Posted 29 July 2022 - 12:05 PM
And thanks to bpirie1000 I went looking for some "before" photos of the head before it was modified. I'd bought a whole bunch of parts off a guy who was moving house and I pretty much grabbed everything in sight. One of the parts was a 12G202 head, which was bare apart from some manifold studs. It didn't look fantastic at the start as it was all grubby with some kind of yellow grease on it. I decided to have a closer look one day and give it a little scrub & it ended up almost looking like a new never used head... the spark plug holes, head stud holes & valve spring seats all looked to have no marks at all. The only real signs of any use was the corrosion around the water jacket and some pitting on the valve seats. What ever it's history it ended up being a perfect base for the head I have now
Edited by timmy850, 29 July 2022 - 12:11 PM.
#768 timmy850
timmy850
  • 3,607 posts
  • Local Club: MITG
Posted 06 August 2022 - 09:32 AM
I had the day off work on Thursday and the plan was to do a quick wheel swap on my Mazda, and then get stuck into the mini. The easy job on the Mazda turned into an ordeal when the wheel stud sheared due to a cross threaded wheel nut. It had recently been serviced, so they are going to fix it for me.
I then got stuck into the head. I removed all the valves and cleaned it up as much as I could.
Next up I measured the combustion chambers so I could calculate the compression ratio
They measured up at 24.6cc, so with my flat top pistons, 1100 bored out 080 over & a couple thou deck height the compression ratio ended up about 11.2:1 . This is quite a bit higher than I was expecting, but it does explain the issues I had getting an appropriate timing curve & the intermittent pinging
This morning I had a bit more time to work on it, first up was to reassemble the head and clean it up ready to put back on the engine
Kg4TgFWh.jpg?1
The exhaust manifold got another coat of high temp silver
The exhaust manifold slips in really easily when the head is removed! It was slightly more tricky than removal thanks to the new O2 sensor bung
The sensor lines up really well and is out of the way of any moving parts. I've still to run the cable into the interior
The Victor Reinz head gasket lines up much better between the 1/2 and 3/4 cylinders and doesn't overhang the bores which is an improvement on the previous ones I've been able to get
Head & rockers torqued up now. I also replaced the bypass hose for piece of mind
By the time I finished up for the day I was able to get the carb & manifold back on and all the fuel/coolant/cables were connected.
Next time I get a chance to work on it, I've got the following to finish:
Set valve clearances
Install exhaust
Add coolant
Oil & coolant flush
Run O2 sensor cable
#769 Clip
Clip
  • 185 posts
Posted 18 August 2022 - 05:22 AM
Wow Tim, been a while since I was active here, but so great to see you are still doing amazing work on your mini. Looking forward to reading back through the last 6months of posts.
#770 timmy850
timmy850
  • 3,607 posts
  • Local Club: MITG
Posted 18 August 2022 - 06:18 AM
Thanks Clip. The last 6 months have probably had more time working on the mini than driving it! The brake issue plus the head gasket has taken up most of my free time. Hopefully I get a few months with no issues !
#771 timmy850
timmy850
  • 3,607 posts
  • Local Club: MITG
Posted 22 August 2022 - 09:38 AM
When I left off I had a few jobs left before I could start up the engine. First up I set all the valve tolerances, then cranked the engine over to confirm I had oil pressure. Everything seemed fine so I put all the spark plugs in to try and start it up - but it wasn't firing. After a few checks I realised I'd unplugged the blackbox ignition just in case I hooked something up backwards. Once it was plugged in it fired right up!
It was a bit too loud with no exhaust on, so I got the mid pipe and mufflers installed. Now it could run for a bit longer I was able to see a decent idle mixture reading for the first time and it was around 13.0 to 13.5 AFR which is a little on the rich side but better than I was expecting. This time running in the new head gasket I ran it dry (of coolant) for about 30 seconds. After the first heat cycle I added water to fill the radiator & heater circuit and left the cap open so that it wouldn't build any pressure.
I did a few laps around the block and everything seemed pretty normal. I noticed the idle and cruise mixtures were both a bit rich (by about 1.0 units) so I had a look at what spare jets I had. I'd been running a 50 idle jet and had a spare 45, so I gave that a go. With a half turn on the idle mix screw it was pretty much spot on. I'll do a bit more checking over the next few drives but it's about as close as I can get it. Out of interest I pulled the choke cable once it was reading the AFR and it dropped from 14.5 down to 11.5 - which explains why it's so easy to foul up with the choke on!
There's still a few jobs left - oil and coolant change, reset valve clearances and retorque the head bolts
#772 johnR
johnR
  • 2,322 posts
Posted 22 August 2022 - 04:19 PM
looking good!
#773 timmy850
timmy850
  • 3,607 posts
  • Local Club: MITG
Posted 02 December 2022 - 09:18 AM
Alright, here's a quick recap of Rylstone 2022 and an update of what's been happening on my mini the last few months.
Due to the previously mentioned head gasket failure I decided that taking my car this year wasn't the best idea. I managed to get it running again the morning we left for Rylstone but there were too many unknowns and I didn't want an "adventure" on the trip this year. I had been a passenger with Phill a few times and we took his car again this year. We had a really smooth trip and didn't have any problems at all. It was nice seeing all the usual mini people and meeting some new ones too!
I bought some Lumenition blue spark plug leads, mainly because I like how they look. I'd had a few issues with the side entry style leads, and the push on ones give a much more solid connection with better water proofing too.
The Swiftune engines are my current inspiration. I love the green engine block with the black rocker cover, of course with the blue plug leads. I found them to be the best price at minispares.
Installation is very easy, but I had to swap the coil boot from my old leads as the new one was a bit too small.
This last weekend I was able to knock out a few jobs, including checking the valve clearances, rear brakes & timing.
One benefit of posting updates is that I get a few more eyes to make sure I don't make any mistakes. When I put in the new rear brake shoes earlier this year I made sure to take a photo of the right orientation. However when I had to replace them a second time I mustn't have paid attention.
Unfortunately I'd installed all 4 rear shoes upside down!
All fixed now
Last up, I always keep an eye out for parts I need and I saw these H4 carbs on eBay. I still needed lots of little linkage parts to complete my existing set, so it seemed like a decent buy.
When they turned up they had AUD178L & R tags, which indicates they are genuine BMC Special Tuning carbs. They still had all the right linkage parts, fuel bowls, choke & return spring anchors. I think now this will be the set I use, and the other sets I have will be used for parts.
I found the parts lists at https://mk1-performa...k/mk1_index.htm and they show most of the original parts are still there. The Australian Special Tuning brochure also had them listed and this set still has the CP4 needles.
The timing has been a constant battle for me since I installed the 1100 engine. Whatever I tried I still ended up with pinging around 3000rpm. Adding the soft mount kit to the carb seemed to help to some extent as it cooled the carb significantly.
I went back and reread the Accuspark Blackbox thread on ausmini a few times and finally had the "lightbulb" moment. This post by minimad caused me to think it all again from scratch: https://www.ausmini....=941745#p941745
I'd used a dwell curve I found later in the thread and not thought too much about it. After reading up on dwell for a few days and making a spreadsheet of dwell vs RPM I came up with some substantial changes to the blackbox settings
Here's where we started:
10 degrees base advance (or so I thought)
20 degrees blackbox advance above 4000rpm - total 30 degrees
Starting with 30 degrees dwell and ramping up to 55 degrees
What I learned:
-Points distributors run a constant 60 degrees of dwell, so I need that as a minimum up top
-The ideal dwell is measured in the time it takes to fully charge the coil. Minimad had specified the charge time as 7ms, and the dwell time is a constant throughout the rpm range. But as the RPM increases the time between sparks decreases, so ideally the dwell degree will increase so that the dwell time stays consistent.
-The blackbox can run a max of 90 degrees - 1/2 the advance. E.g. at 20 degrees advance you can run a max of 80 degrees dwell.
-Running less dwell at lower RPM will reduce the heat while maintaining the spark
-The accuspark instructions suggest a low limit of 20 degrees and high of 75 degrees.
-I can upgrade to a 1.5 ohm coil with an appropriate dwell curve
-I also checked the base timing and what I thought was 10 degrees was in fact 21 degrees. I have no idea how long it's been like this and why it was so high. This means I had over 40 degrees max, which quite possibly explains the head gasket failure.
Where I ended up:
15 degrees base advance
15 degrees blackbox advance above 4000rpm - total 30 degrees
Starting with 23 degrees dwell and ramping up to 70 degrees. I can potentially add more dwell at higher RPM
So far it seems to be working really well. My theory is that the coil was undercharged due to the low dwell and this was causing a poor spark. I'll keep testing it to see if this has solved my problem, and possibly upgrade to a 1.5 ohm coil and open the spark plug gap. I might be able to add some more timing again if this solves my previous issue.
However, I've also bought a Pulsar distributor with CB Performance Blackbox & 1.5 ohm flamethrower coil. It has a few advantages over the Lucas setup & the CB unit includes a MAP sensor for load based timing correction
#774 timmy850
timmy850
  • 3,607 posts
  • Local Club: MITG
Posted 07 December 2022 - 09:24 AM
I stripped all the unnecessary parts from the new carbs and put them on a proper mini manifold with the ram pipes. There’s something about old carbs with that stale fuel smell I find really appealing  :lol:
We had the last Minis in the Gong drive for the year on Sunday and it was a perfect sunny day. We had a small but varied group of minis
#775 PoolGuy
PoolGuy
  • 981 posts
Posted 07 December 2022 - 09:44 AM
It accelerates well out of hairpins!
#776 timmy850
timmy850
  • 3,607 posts
  • Local Club: MITG
Posted 07 December 2022 - 10:25 AM
And that’s up the steep bit too!
We had another climb up a hill on the way to lunch and I was waiting for the steep bit to start - with the old 998 engine I’d have to go back to 2nd and go up full throttle - but with the 1100 engine it cruised up at part throttle in 3rd gear
#777 timmy850
timmy850
  • 3,607 posts
  • Local Club: MITG
Posted 05 January 2023 - 11:56 PM
So a last update for the end of 2022 and a few plans for the year to come:
I have 99% finished the dual HS2 carbs on the Peter Manton manifold. All that's left now is to splay the throttle blade screws, set the fuel bowl levels and get them synchronised and installed. I had a fun morning a few weeks back swapping intake manifold studs, the Manton manifold had short studs, the Cooper S manifold had medium length studs & the Midget manifold that came with the H4 carbs had really long studs. The Manton manifold ended up needing the medium length ones & the Cooper S got the long studs. (I sold the Midget manifold - ironically back to the guy I bought the carbs and manifold from)
I bought these large radius HS2 stacks from eBay a while back in the hope they'd fit inside a Ramflo. They fit inside nicely and will just need some very slight trimming to the plastic cage. There will be a decent air gap all around the stack. They'll need an allen head bolt to fasten them up, so I need to track some of them down.
They ended up looking pretty nice! The plan is to use the original abutment plate from my 850, with the choke coming up from the bottom of the RH carb. I will try using a single choke and see how well this works, if it needs another choke on the other carb I might need to run twin cables. The manifold ended up needing quite a bit of a clean up to work with the exhaust manifold flange. I had to square up the inner corners with a file to get it to work (although it would have worked fine on an 850 with a cut off standard manifold)
I enjoyed the twin HS2 carbs when I had them a few years back, but I kept having a strange issue I couldn't quite work out. In hindsight it could have been the start of the first head gasket failure, but hard to know now. I will be starting with the same HV3 needles that worked for me last time, although I will be using some yellow dashpot springs. Last time I used blue springs and never got around to trying the yellow. I'm planning on getting these running soon so I can learn a bit more about twin SU tuning by the time I can get the H4 carbs ready.
My new ignition system finally arrived. We've got:
Hitachi/Nissan Pulsar D4R83 distributor, which already has the mechanical advance locked
3.0 ohm flamethrower coils - one used and one new
New GH617 cap
Laptop for tuning & the required cable
There's a few little things to fix up, like an exposed wire near the clip
The vacuum advance canister has been removed, but the advance plate is now free to rotate. I will lock this up to be fixed
I found my local auto parts shop had the rotors in stock - part GH605. It's a genuine Japanese made Bosch part and cost me a whopping $0.60!
#778 bpirie1000
bpirie1000
  • Area Managers
  • 2,566 posts
  • Local Club: Amoc
Posted 10 January 2023 - 10:21 AM
Brilliant, absolutly brilliant... such motivation for me to get back into the garage and get going with my fleet..
Well done and good to see such an amount of mini pals local to you..
#779 timmy850
timmy850
  • 3,607 posts
  • Local Club: MITG
Posted 13 January 2023 - 10:42 AM
So what's my plan for 2023?
First job of the year was to pack up and move all my parts and tools out of my parent's single garage into our temporary rental. I definitely regret hoarding so much stuff now, I filled up this large box trailer twice + the tray of the ute... I managed to find a few things and discovered other things I'd completely forgotten about. We'll be moving again in a few months (once our new house is built) so this will give me a decent chance to clear some room.
In terms of projects on the mini I've got a few things on the list:
Install KAD rear camber/toe brackets
Install bucket seats
Finish twin HS2 carbs and install them. I might have bought some shiny ram pipes to fit on them too!
Rebuild H4 carbs and try them too
Install new distributor & ignition management
Progress SA1100 engine (poor man’s 1071)
Fix up and enjoy old steering wheel(s)
I'd like to put my old Britax seatbelts back in as they hold you in a bit tighter & I don't tend to get passengers much anymore (one of the reasons I had the modern retractables)
#780 timmy850
timmy850
  • 3,607 posts
  • Local Club: MITG
Posted 06 March 2023 - 10:41 AM
One mistake I made late in 2022 was driving about 15km with the O2 sensor in the exhaust and the gauge disconnected. I had read it was a bad thing to do in the manual but I completely forgot to plug it back in. By the time I got back home it was only reading 7.4 or 22.4 which is max rich or lean. I checked the number on the sensor and it was a generic Bosch part, so ordered in a new one. It took me a few weeks to get a chance to swap the sensor and I thought I may as well try a fresh air calibration on the old sensor to see if it'd come good. Happily the old sensor started reading fine again after the calibration and seems to be working OK now.
After a few weeks sitting I finally took it for a drive in mid February. It seemed to be running ok, the gauge was reading fine most of the time but when trying to take off the line, or when stabbing the throttle it was bogging and showing lean on the gauge. I guessed this would be due to a problem in the pump jet circuit, so I stripped it down and checked a few things on the way. The pump jet on one side of the carb was getting a lot more fuel than the other side, so I pulled off the carb and gave it a good clean out. When I reassembled it I tested both sides were squirting the same amount of fuel, and they were all good.
Next I wanted to check the balance between the idle jet size and the idle mixture screw. The jet sizing is a coarse adjustment and the screw is a fine adjustment when setting the idle and low speed fuel mixture. The tuning manual says to start with the idle screws at 3.5 turns out, and to up the jet size if you need more than 4 turns out to get a decent mixture. I checked and it turns out I had +6 turns out which means that I was compensating for the lean idle jet (45) by making the idle mixture screw richer. When I reset the idle screws to 3.5 turns I was getting an idle mixture of >17:1 which is no good
I went through the jet stash and got some 50 idle jets & left the idle screws at 3.5 turns. It fired up and had a decent idle at 14.5:1. The added fuel under load completely transformed the driving, to the point where there’s no weird spots down low, and stabbing the throttle doesn’t cause any bogging or stumbling. The only downside now is that the gauge is showing it’s really rich (10/12:1 under load and 13:1 cruise) but if you ignore the gauge it drives really nice.
I also needed to replace one of the grommets on the radiator bracket, which turned into a surprisingly frustrating job.
This week I decided to check what the vacuum reading was like on the Dellorto, as soon I'm planning on using the CB Blackbox which has a MAP sensor. The general opinion is that Weber and Dellorto side draft carbs will give you a poor vacuum signal, especially at idle. I decided to check mine and the results were:
Each port at idle gave a choppy reading, but smoothed out with some throttle
When the two ports were joined with a T piece there was a nice smooth vacuum reading everywhere
So I decided to hook up the vacuum ports to the vacuum advance on the distributor. I have the original 25d distributor which uses a screw on vacuum hose. I don’t have this anymore, so I swapped the vacuum can to a later one that takes a rubber hose.
The original is a 7-13-5 which means the vac advance starts at 7”Hg and tops out at 13”Hg and gives a total of 5 degrees advance
The later one is 3-9-8, so it gives more advance at less vacuum which I thought might be a bit excessive..
I hooked it all up and checked the idle timing and I was getting an extra 8-10 degrees at idle, which is exactly where it should be. The additional timing meant I could reduce the idle speed at the throttle screw to give the same idle speed as before.
It now has a lot more response at low rpm and throttle inputs when the vacuum is high. It’s now really easy to get off the line. The additional timing at part throttle cruising should also mean less throttle opening is needed and slightly better fuel economy
The frustrating part is this is exactly how it was setup when I first put in the 1100 engine. I had the same carb, similar jets and I had the vacuum advance hooked up. I keep going around in circles trying to solve my irregular pinging issue, which I'm now confident was the incorrect dwell setting on the Accuspark blackbox. Hopefully it's all good from here on!
    Bing (2)
