So, after I first got the car started on the 11th I still had a couple of jobs to do:
Fill up the radiator
Add the throttle cable
Connect up the heater hose
Add the overflow bottle
Check the timing, tappet clearances & retorque the head after a heat cycle
For reference the advance timing is set electronically by the accuspark blackbox unit based on the ignition table loaded into it.
I had some time on Wednesday morning to try and sort a couple of things out - first I topped up the radiator and then started the engine to try and bleed the system. It was at this point I noticed that the bypass hose wasn't tight and it was leaking water out. As I went to tighten up both the hose clamps I noticed that one of them was missing and it turned out to be on the floor... It took me about 45 minutes to get a hose clamp unwound, then slipped over the hose and tightened up. After that debacle I thought I'd check the timing - but the car now wouldn't start, and it seemed to be spark or timing. I tried sweeping the dissy around a bit looking for the right spot and it just wouldn't start. I pulled out a plug and cranked it over and the spark was weak and not consistent . I put the battery on to charge for the night and tried to think of some solutions
Thursday I thought I'd start by checking the program in the blackbox unit to see if there were any errors. It all was ok and had the old program I'd loaded, so I did all the same checks on the ignition circuit and still wouldn't start. I also tried with the blackbox bypassed and no change. At this point I was starting to get a bit frustrated!
On Saturday afternoon I went and picked up an 850 block and gearbox from a friend (story for later) and he kindly lent me a working distributor with electronic ignition, working coil and a spare set of leads. I tried every combination of distributor/coil/leads/cap/rotor I had and I still had no luck. The last resort was a set of points that I'd bought, only I needed to buy a condenser.
Sunday morning I popped into my local independent parts shop and bought another new set of spark plugs and he even had a Bosch condenser with the right part number reference on the shelf! Once I figured out how to wire up the points I thought I'd give it a go at starting. It literally started on the first press of the starter button and had a nice smooth idle. It ran really nicely and had steady timing with the blackbox bypassed (as the mechanical advance is locked out). When I connected the points to the blackbox it started to have issues with the advance as the rpm picked up. I was able to drive it around the block, but for whatever reason the points and blackbox aren't working together.
During some spare time I wasn't trying to fix the car I did a couple of little jobs. Previously the wheels had a coat of matt black paint, but I wanted to go back to the bare alloy finish. They look pretty cool with the caps on there now
I had a long day working on the car last Thursday, all the quick jobs I had ended up taking forever. The first seemingly simple job was to undo the lock wire and get the advance springs back in the distributor. A couple of minutes later I had it all back in the car and it started up fine. I checked the timing and it was spot on, and the idle was very smooth - the only problem being that I had no advance when I revved up the engine. I pulled it all back out again and found that the advance cam was not rotating at all. I failed miserably trying to get the drive gear off the end of the distributor spindle, and had to go and get a new punch to get it out. Once the spindle was out it took me a bit of time to slowly lever off the advance cam - it was stuck really hard with a combination of solidified grease and rust. Next it was all cleaned up and greased, now it moved smoothly and everything worked as it should. One thing to note before you pull off the advance cam is the position of the drive gear - it is possible to put it on 180 degrees out which is a bit of a pain when you try and start the engine! That all ended up taking about 2 hours.. Yet another part that I now know too much about
I did an oil change, checked a bunch of the things that I'd messed with in the last few weeks and took it for a decent drive around town to check everything was working as it should. It seemed to drive even better than before, I'm not sure if previously the gasket was on the way out, the timing now is better or if I'm just not used to driving it but it was a bunch of fun. I've got to get my confidence up again, it's hard to get the experience of the sudden head gasket failure out of your head
I also managed a quick wash and vacuum today too, so it's all ready to go for the MITG drive on the weekend.
On Sunday we had a nice drive out through the Wollondilly Shire. It took us 3 goes to find an open cafe for morning tea, and we ended up at a nice one in Thirlmere. From there on to The Oaks for lunch at the pub.
8E98840C-7271-4F43-A609-CE20058CA8CA.jpeg 95.18K
0 downloads
Overall the car did really well. There are a couple of weird noises, one being the speedo cable and the other I need to track down
